acceleration problem
Old Nov 15, 2005 | 11:33 PM
Autobadges.com's Avatar
Autobadges.com
Banned
Default RE: acceleration problem
then edit your posts not post after post! haha jk harv
mikel72's Avatar
mikel72
I didn't do anything to the MAF. Somedays the car runs GREAT with no problems. But, it seems when the car gets to about 1/2 tank of gas, the car starts having the problem. I know just keep a full tank of gas in it and it'S fixed. I NEED HELP.
Old Nov 15, 2005 | 11:36 PM
03YellowPony's Avatar
03YellowPony
AHHHHHHHHHHHHHHHH! Another piece of the puzzle.... Might have something restricting the fuel pick-up...when it's down past 1/2 tank, have the fuel pressure tested. Could also be the fuel pump, but I doubt it if it does ok with a full tank...
But I would highly recommend cleaning the MAF also. With almost 100k, it probably needs it. BE CAREFUL when you do it. Use either alcohol(NOT THE DISTILLERY KIND) or carb cleaner with a Q-Tip. CAREFULLY clean the wire. If you break it, you just bought a new one.
Old Nov 15, 2005 | 11:37 PM
mikel72's Avatar
mikel72
Would the OBDII pickup the codes for O2 sensor. I'm going to buy a fuel pressure gauge tomorrow.
thanks
ORIGINAL: 03YellowPony
2 other things I'd check. 1 fuel pressure. You'll need to either buy a meter, or take it to a shop. And 2 O2 sensors. You will again either have to buy a meter, or flash tuner, or take it to a shop.....
Autobadges.com
Banned
FUEL PRESSURE TEST AT IDLE!!!! That will tell you a LOT
Old Nov 15, 2005 | 11:39 PM
03YellowPony
ORIGINAL: mikel72
thanks
Not necessarily if they are boarderline. Depends on the circumstances.
Old Nov 15, 2005 | 11:40 PM
Autobadges.com
Banned
soemthing is definately up with the fuel system if it only happens with low fuel...i BET the fuel pressure test will show you. Its probably the fuel pump. The filter only cleans the fuel out...nothing more, no pushing or anything...the injectors may be a culprit too as they "shoot" it into the engine...but it sounds like the FUEL PUMP. If it doesn't pump it out well.....or bc fuel is low it needs to pump harder...that sounds like your issue...
Old Nov 15, 2005 | 11:43 PM
03YellowPony
ORIGINAL: Autobadges.com
I agree. I'm leaning on the pump itself, or the screen maybe getting clogged..restricting the pick-up. If it does turn out to be the pump, change the screen too!
Old Nov 15, 2005 | 11:46 PM
mikel72's Avatar
mikel72
Thanks, I'll test it out. how much is a fuel pump.
Autobadges.com
Banned
Exactly Harvey.
Sometimes the screen does get cruddy after a while...but while you are at it....its WAY better to completely swap the pump to have it all new as they are not expensive at all.
Hell my Fuel Pump is Walbro 255 and it was $125 I think
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
zanemoseley
Sep 6, 2015 12:58 PM
