FINALLY!!
Old Nov 19, 2005 | 07:42 PM
03YellowPony's Avatar
03YellowPony
Default FINALLY!!
Ok AutoBadges...I got off my a$$ and installed the fog lites, Throttle Body, plugs and wires. And THANKS for the wires! Purty yellow!
I can tell y'all one thing. It's a BIOTCH doing the plugs on the passenger side. ESPECIALLY if you put in a strut brace before doing the plugs! [:@] The only saving grace was, I decided to do the T/B too. When you take off the T/B, the access to the rear plugs is a lot better!
I also ported the intake for the new T/B. Man what a diference!
Now if the pony stickers would only get here...thgen I can put on the drilled and slotted rotors, and Hawke pads!
Umm..anyone know where I can get Yellow caliper paint? None of the local parts stores has it.
Old Nov 19, 2005 | 07:54 PM
ByPopularDemand's Avatar
ByPopularDemand
Default RE: FINALLY!!
cool how does the fog lamp install work. Did you install a switch too
Old Nov 19, 2005 | 08:02 PM
03YellowPony
The kit comes with the wires...hardest part was mounting the lights. The 2 screws on the top, you can't see them. You have to feel your way. And only 1 wire goes into the cabin. The wiring harness and connector are already there. All you do is pop off the cover around the A/C and stereo, unplug the connector from the blank, tap the blue wire into the white/black striped wire and plug it into the switch. The switch fits right in where the blank was. A snap! Actually, the hard part was goung down to the parts store with the bezel hangin, to get a DECENT wire tap, as the one in the kit was S**T!!!
Old Nov 19, 2005 | 11:41 PM
mustangman02232's Avatar
mustangman02232
where did you get the lights from?
Old Nov 20, 2005 | 12:14 AM
03YellowPony
E-Bay
Old Nov 20, 2005 | 12:25 AM
jthorn9's Avatar
jthorn9
The Godfather
[sm=chairshot.gif] Harvey wash your mouth out with soap for saying such a dirty word. JK, ebay is good for some things.
Old Nov 20, 2005 | 12:43 AM
03YellowPony
I know...[:'(]
Old Nov 20, 2005 | 01:35 AM
babygurl2000's Avatar
babygurl2000
I ♥ Acer
you did it different than i did then
mine was an easy install
i got the GT switch too did you?
i wired mine into the running lights
so i have them on with the parking lights
kewl...
Old Nov 20, 2005 | 01:56 AM
03YellowPony
ORIGINAL: babygurl2000
kewl...
I got the stock Ford switch that goes next to the TCS switch. And yes, they turn on with the parking lites.
Old Nov 20, 2005 | 02:18 AM
JonBeast's Avatar
JonBeast
Moderator
Your building up quite a mod list there 03 [sm=smiley20.gif]
Buy some high temperature engine paint for your calipers. You can find it pretty much at every hardware/auto parts store.
