supercoupe supercharger
Old Nov 24, 2005 | 02:07 PM
w8less's Avatar
w8less
Default supercoupe supercharger
will a supercoupe supercharger work on my gf's 98 v6 mustang? and if so what all would have to be changed? and if so ne advice to make it a easy install
Old Nov 24, 2005 | 02:57 PM
hawks05's Avatar
hawks05
Default RE: supercoupe supercharger
it takes tooo much work to do i had been looking into doing it not worth it just buy a vortech or a procharger be a hell of a lot cheaper install on the supercoupe parts they are cheap but its the labor that will cost you its not something that your semi-mechanically skilled can just slap on.
Old Nov 25, 2005 | 05:26 AM
Autobadges.com's Avatar
Autobadges.com
Banned
LOTS of work...this has been a big topic. I have a friend that did it and took LOTS of work....better to buy a new s/c
Old Nov 25, 2005 | 11:21 AM
nanaki's Avatar
nanaki
Retired MF Moderator
ORIGINAL: Autobadges.com
how much did he end up spending when it was all said and done?
Old Nov 25, 2005 | 02:53 PM
Autobadges.com
Banned
Hmmm couldn't remember about $1000 plus massive massive hours of labor and research
Old Nov 27, 2005 | 11:21 AM
cliffloehr's Avatar
cliffloehr
Whats with all this negitivity?
This is a GREAT idea!
I've started this exact project with my 2001 mustang and don't think it's that big of a deal.
And my stang has split-port heads adding a lot of extra labor... but I know it'll be worth it!
The roots blower looks MUCH better then one that bolts on the front of the engine and it puts out 12 to 15 psi.
Last week a picked up a supercoupe engine (in parts) for $150... So now I got the M90 blower, and most of the hardware needed to get'r started.
Because the blower bolts to the lower intake, and the SC has single port heads, I'll be cutting the top off my lower intake (gutting it out) and welding the top of the supercoup intake to it.
There's a good thread on the a supercoupe form (http://www.sccoa.com/forums/showthre...ight=splitport)
Old Nov 27, 2005 | 02:09 PM
nanaki's Avatar
nanaki
how long you think it's gonna take? autobadges is mainly talking about the hours and research involved. $1000 in parts really isn't as bad, but if it takes like a month of your time, why bother? might as have pieced together and fabricated your own turbo at that point.
Old Nov 27, 2005 | 11:59 PM
cliffloehr's Avatar
cliffloehr
Thats a good question...
I figure a day to tare it down, a day or two to fab up the Intake, a few days to put it back together... and 2 months to research everything and find all the parts.
Old Nov 28, 2005 | 12:24 AM
cliffloehr's Avatar
cliffloehr
ORIGINAL: Jasperstang308
I'm making this mod for my '01 Mustang... but your car does not have split-port heads (started in 1999) so the adding the M90 blower would be MUCH easier.
You can bolt the stock supercoupe intake+blower directly onto your engine. The blower is driven be an independent belt, so you'll need several other components to support it, but they would all be found on the thunderbird supercoupe.
Roadhawg's Avatar
Roadhawg
I did it and it was well worth it.
