engine rebuild
My mustang is getting around 90,000 miles and i plan on getting ported heads and intake and new cam, and some other mods. I was plannning on having my engine rebuilt too. Any one know where a good place to buy a rebuilt kit at and how much it would cost me for labor. thanks
Crap, there was a post made about a month ago that had a link to a rebuilt engine site and I forgot where it is, search throughout the forums and look for it, it may be more than a month old though. Also, shops charge about $55-$80 an hour and your looking at at least 6 hours of work for a pro, so its not going to be cheap, but your new engine will be so worth it, and your cars resell value will jump up nicely to.
go to www.40bob.com and www.powerheads.com/23turbo. 40bob has a fully ported intake and 65mm throttle body. powerheads has a pretty sweet ported and polished head with a hydrolic roller turbo cam setup. thats if you have a 2.3L motor! if not sorry then.
get a master kit i dont know if ground hammer makes cams for v-6 cars but they are killer cam and lifter sets but then again its your car only a sugestion im in the middle of building a 2,3 for my wifes probe and a 351 clevland for mt stang im gettin outa the four banger catagory
have your heads flowed on a flow bench then you will be able to see the lift points that flow the most air and get a cam to match that is the MOST importent thing you can do and one of the easiest way to get more power talk to the machinest about doing a valve job and getting bigger valves more air=more power
Let me send you to one of MY sponsors that helped me rebuild my little V6 Mustang
Name is Mikael (MICK-L) and is the owner of www.rpm-mustangs.com He does cams, heads, intakes etc especially for V6 mustangs.....and did mine as well.
Email him at sales@rpm-mustangs.com and drop the name EVAL so he knows I sent you.
ORIGINAL: Autobadges.com
Mik hooked me up and went the extra mile for me. he is an asset for the 3.8-4.2 community
my 98 will have a set of his BV heads within the next 6 months
