THERMO SENSOR
Old Nov 29, 2005 | 06:22 PM
WhItEvEnOm's Avatar
WhItEvEnOm
Default THERMO SENSOR
Hey........question would a bad thermo sensor cause a car to overheat???????????97 ford mustang..........and if so where is it located...........and does it have any affilation with the electronic fan?????????
Old Nov 29, 2005 | 11:21 PM
Autobadges.com's Avatar
Autobadges.com
Banned
Default RE: THERMO SENSOR
OF COURSE...it is what OPENS to allow the coolant into the engine..w/o that working your car will massively overheat and cause major damage. It is located after the top radiator hose where it connects to the engine usually.
It has not affiliation so to speak as its a mechanical thermo...and we have electric fans
Old Nov 30, 2005 | 04:00 PM
WhItEvEnOm's Avatar
WhItEvEnOm
Yeah i know that thats the thermo stat.........I heard that theres a sensor that cuts your fan on when your car starts to get a little hot...........Heres my story....i was driving back from my grandparents house and i was on a highway so i was going pretty fast about 75mph then i heard a clicking noise, then i pulled over to check it out then my car started to overheat a little bet.......so far i replaced the radiator, both hoses, t-stat, serpintine belt.......my water pump isnt leaking through the **** hole so it seems fine???I just did a oil change about 4 days ago.. Me thinking that the car is fixed i take it for a test drive and after a little bet the temp gauge shoots way up to about the L??????????I don't know whta more to do i need some help???????????????????????????
Old Nov 30, 2005 | 04:59 PM
Autobadges.com
Banned
its your fan then. It's not kicking on to cool the radiator
Old Nov 30, 2005 | 05:01 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: WhItEvEnOm
Umm that's called the Thermo Fan Switch.....
Old Nov 30, 2005 | 05:03 PM
Autobadges.com
Banned
Right-o-mundo Harvey!
Old Nov 30, 2005 | 05:31 PM
TorchV6's Avatar
TorchV6
that sucks you went through all the trouble of replacing everything else but at least you shouldnt have to replace all of that other stuff for a while now and yea it is the thermo fan switch like harv and erick said...
Old Nov 30, 2005 | 07:51 PM
WhItEvEnOm's Avatar
WhItEvEnOm
well ive checked my fan and it comes on but not intill it gets really hot........maybee malfunctining and it comes on whgem my a/c is on?????where can i buy this thermo fan switch at?????? if the case maybe
Old Nov 30, 2005 | 08:22 PM
03YellowPony
Any good local parts store should have it. And I think it's a real good possibility the Fan Stitch is bad. Either that or your coolant has a nice sized air pocket where the switch is. That will make the fan kick on way too late.
Old Nov 30, 2005 | 08:40 PM
WhItEvEnOm's Avatar
WhItEvEnOm
well how do you get a air lock out of your system...........do you undo a plug or just idle the car???????thanks yellowpnoy
