door windows
Old Dec 6, 2005 | 11:00 PM
p0rsche23's Avatar
p0rsche23
Default door windows
Has anyone ever changed the door windows themself?....I was looking in my manual and it looks not that hard at all and was just wondering if anyone has gone through the procedure and how hard it was......Also same question about the windshield,manual says get a pro cuz of the adhesive but I would like to save hella $$$ by not having someone install it for 300 or more......
Old Dec 6, 2005 | 11:08 PM
rob_boura's Avatar
rob_boura
Default RE: door windows
neither ones hard but it helps to have some one to help cause your dealin with glass one slip and your outa a window door indows are aey is yours alreay out? or broken?
it pins to the track with the pins and spacers and bushings easy way to get one out or put one in is to get the pins and hardware out when the windows out and to moove the window track down while havin some one hold it up hte angle it to get it out then you know how to get the new one in it only takes an hour or two
as far as the winsheild go its not all that har to get one out if you have a heat gun to soften the sealer and tar compund and puttin a new one in is easy if you have help all you so is get tarstrip iwndow sealer fron advanced or autozone and its about 6 bucks yours has the rubber strip rite you take the strip sealer around the seat for the winsheild and put the rubber arount the winsheild as you line it up to be set take matbe 2 hrs with help
Old Dec 6, 2005 | 11:12 PM
jthorn9's Avatar
jthorn9
The Godfather
Well I've never done it, but be sure to get your wiring installed straight, because if you don't you will have some serious window problems.
Old Dec 6, 2005 | 11:14 PM
rob_boura's Avatar
rob_boura
hes only talkin bout the glass i think
Old Dec 6, 2005 | 11:16 PM
jthorn9's Avatar
jthorn9
The Godfather
Yea I know, but if he has to undo any switches or wiring, he could be in for a long ride.
Old Dec 6, 2005 | 11:28 PM
rob_boura's Avatar
rob_boura
yeah but we all know the plugs all line up diff and if not you just look at the wire colors bro easy as one two three
Old Dec 6, 2005 | 11:30 PM
03YellowPony's Avatar
03YellowPony
Window glass is easy to do. Windshield is another matter. DON'T try it unless there is someone with you that has experience. You can mess up REALLY well VERY easily!
Old Dec 7, 2005 | 12:17 AM
03mustangdude's Avatar
03mustangdude
is it hard to do this i got a mini problem but it doesn't really both me
on the drivers side master window control i can put down the drivers and put it back up, can put down the passengers but i can't put it back up for some reason i gotta go over and put it up on the passengers controls, i don't really care right now cuz it's hella cold but in the summer it might be annoying....
Old Dec 7, 2005 | 01:24 AM
p0rsche23's Avatar
p0rsche23
Well I guess whoever had it first, or maybe the dealer,had tried to scratch the stock tint off to make it clear? I dont know it looks weird its all scratched up like a razor blade was used....but if I figured how to do it,I was going to take the drivers door window out too and just tint them while they are both off cuz it would make it so much easier.....I figured that the windshield would be pretty hard....
And does anyone know the legal tint percent on the windshield? I think its like what 15% on the side windows and other than that u can put w/e....thanks
Edit... Sorry I meant to put in Texas..thought I did......
Old Dec 7, 2005 | 01:47 AM
gt96stang's Avatar
gt96stang
Tint depends on state to state specs on what they say is legal.
