Got this error code NEED HELP!
Old Dec 29, 2005 | 09:21 PM
Smallpox33's Avatar
Smallpox33
Default Got this error code NEED HELP!
I threw a check engine light and now im getting this code
it gives me it 4 times
DTC P0320
ignition/Dist
Engine Speed Input
Circuit malfunction
Anyone have any ideas as to what this might be? the car runs and drives fine except for a slight exhuast leak.
Old Dec 29, 2005 | 09:42 PM
03YellowPony's Avatar
03YellowPony
Default RE: Got this error code NEED HELP!
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
Check plug wires. Make sure there are no cracks in the insualion, no discolored spots. And make sure they are CONNECTED correctly. If there is any discoloration, replace the wires.
~EDIT~
That's a starting point...Could be a weak coil, bad reluctor...almost anything.
Old Dec 29, 2005 | 11:04 PM
Smallpox33's Avatar
Smallpox33
yep! thanks alot, one of the wires had a tear in it and it was grounding out so i taped it with electrical tape and reset the computer and bam no ehck engine code, now i got to see where i can get these wires replaced, theyre vitek? i think they have a lifetime warranty
Old Dec 30, 2005 | 02:33 AM
03YellowPony
ORIGINAL: Smallpox33
Good to know I actually helped! If you can't find the manufacturer(try Google), go with some 8.0 or 8.5 mm high energy wires.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Dathan
Oct 5, 2015 05:52 AM
