POWER
Old Jan 15, 2006 | 03:44 AM
blkmustang629's Avatar
blkmustang629
Default POWER
I wrote a recent post about supercharging, now i think im leaning towards turbo for my car. What would you do if you had the choice of supercharging or turboing your stang, which system would you set up?
Old Jan 15, 2006 | 12:49 PM
2004YellowStang's Avatar
2004YellowStang
Default RE: POWER
Hands down definetly a turbo. A turbo has a greater power potential than what a supercharger has. Take a look on www.tmaturbo.com for some turbo kits. Not to mention the turbo kits are a tad bit cheaper.
Old Jan 15, 2006 | 01:37 PM
nanaki's Avatar
nanaki
Retired MF Moderator
Default RE: POWER
unless you plan on building your engine up to take advantage of a turbo's full potential, i wouldn't even waste the time and money on it. everyone wants to go with a turbo, but most don't realize how much time and money is involved in it. a supercharger you can put on in a day.
Old Jan 15, 2006 | 02:13 PM
mustangman02232's Avatar
mustangman02232
Default RE: POWER
ORIGINAL: nanaki
the guy from VMP is running 17 psi through a stock block, a supercharger especially a centrifical will be cheap and easy, but you dont make as much power, if you really want to go with a turbo, just make sure you do it right and have it profesionally installed
Old Jan 15, 2006 | 02:16 PM
nanaki's Avatar
nanaki
Default RE: POWER
is that car his daily driver or does it get trailered to the track?
just because one guy's car can take that kind of punishment, doesn't mean everyone's can.
Old Jan 15, 2006 | 02:39 PM
mustangman02232
Default RE: POWER
ORIGINAL: nanaki
i dont know i just saw something on it, nothing wrong with a DD 10 sec V-6 gas probably sucks though
Old Jan 15, 2006 | 05:18 PM
cobra232's Avatar
cobra232
Default RE: POWER
justin's car is a daily driver at 14psi and pump gas on an internally stock 3.8
Old Jan 15, 2006 | 06:26 PM
ByPopularDemand's Avatar
ByPopularDemand
Default RE: POWER
ORIGINAL: nanaki
Dont you need to build up an engine to get all the potential out of a S/C too
Old Jan 15, 2006 | 06:47 PM
Jugador's Avatar
Jugador
Default RE: POWER
yes, but it doesn't take as much fabrication or money to get a supercharger. nan is just saying how he thinks doing a turbo is only worthwhile if you're going to use it to its fullest potential.
Old Jan 15, 2006 | 08:40 PM
ByPopularDemand
Default RE: POWER
Fabrication=forging??
