newagetuning?
New age tuning is defunct because their M-90 splitport kit never materilized after a couple years of hype
V6sprout from www.v6power.net did some freelance R&D for them but was not a partner i believe.
the guy called speedkillz was the owner of newagetuning.com and imo was a big BS'er that never got his act together for the kit
i knew i would get u in here cobra, i couldnt find your name lol. i tried to find sprout he wasnt on, but he swapped the whole engine in. i found one of the s/c.s , intercooler, tubing, lower intake manifold, pulleys, belt tensioners, upper and lower plenums and new belts for 300. do you think that will be all i need to install this? i mean i can get pipe bent and cut for the intercooler at any truck place.
ORIGINAL: Sickspackstang
$300 for almost the same power that i spent $3000 to get
go for it you won't be sorry. it may take a little longer to figuer out but as long as you have everything you can make it work and it will make you nice power. like i said there are many choices to upgrade the M-90 as well as putting heads on you car with a nice cam and it can be made to scream.
but like how serious of an undergoing is this? basically ill rebuild the supercharger and what it bolts right onto the intake manifold? do i need an ecu change?
well heres a pic of a m90 on a 98 3.8L , looks like alot of work just from the pulley system lol. but otherwise it looks pretty straight forward...
[IMG]local://upfiles/14411/AF6F5F73EC1047DFBF0F42531030F03E.jpg[/IMG]
