Wiring Help Needed!
Old May 4, 2003 | 01:49 AM
per4merpc's Avatar
per4merpc
Default Wiring Help Needed!
Hi,
I have a 2002 Ford Mustang V6, Bone Stock. Iam trying to install a accessory that needs a 12v supply that is switched from the ignition. Which wire do i use to get a 12v switched power source? How do i get to it?
Thank You
Old Aug 7, 2004 | 02:29 AM
Drizzt6534's Avatar
Drizzt6534
Default RE: Wiring Help Needed!
Well the red wire is the power wire, but i dunno what you're talkin about with this ignition stuff
Old Aug 7, 2004 | 04:10 AM
HRnB's Avatar
HRnB
Administrator
You can come right off your fuse box. They make this cool little plug that plugs into the fuse socket then the fuse into to it. Just use you radio or ign fuse.
importsmasher
Oct 9, 2015 04:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
Nurdyguy
Aug 21, 2015 10:23 PM
bigdaddy51200
Aug 19, 2015 05:09 AM
defarmer
Aug 13, 2015 06:40 AM
