safe hp??
Make sure you do the proper modifications to your engine to be able to take any major or even moderate type of boost, because the last thing you need is to blow a cylinder or two. Personally I think nitrous is way overated because one, its expensive as hell to buy, install, and refill the tanks, two its dangerous, because technically you're a driving bomb, and three, when in the hell will you ever get to use it because most people never see a track, I say do rebuild your engine, add a T/C, or rebuild your tranny, all cost about the same in the long run, and give you instant boost of speed and or hp without the extreme risk of screwing up your engine or killing you from some Fd up explosion, but that's just my two cents, and you're not going to change my opinion on that one.
100 is probably the max your car can take. i'd do a 75 if i were you though. just like us GTers can take a 125 (actually 150 according to some), but most do 100 just to be safer. make sure you get a flip chip with a nitrous tune on it though.
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
