how much?
Old Feb 2, 2006 | 12:47 AM
WhItEvEnOm's Avatar
WhItEvEnOm
Default how much?
can you put a 99-2003 engine into a 97 model 3.8l????and if you can how much would that engine cost????if not how much would a 97 3.8l engine cost me??
Old Feb 2, 2006 | 02:18 AM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: how much?
Yea you can, but you'll need to change out a crap load of stuff as you'll need to basically make that 97 a 99+ outside of the body, because the engine has a totally different ecu, coil pack location, different air intake setup, and many other things. But yea it will fit as the 94-04 are basically the same frame, just the edges have a more powerful modern engine and the body is slightly squared off, but outside of that, they're the same car.
Old Feb 2, 2006 | 08:45 AM
nanaki's Avatar
nanaki
Retired MF Moderator
if you're doing an engine swap, you're better off getting something else. all that time and money wouldn't be worth just having an extra 40HP.
Old Feb 2, 2006 | 09:06 AM
mustangman02232's Avatar
mustangman02232
ORIGINAL: nanaki
ya i would get another 97 motor just because of the electronics, if you want more power get a used SC with a supercharger
Old Feb 2, 2006 | 09:12 AM
nanaki's Avatar
nanaki
ORIGINAL: mustangman02232
ORIGINAL: nanaki
an SC with an SC? SIGN ME UP!
Old Feb 2, 2006 | 09:43 AM
1BAD3V's Avatar
1BAD3V
ORIGINAL: nanaki
ORIGINAL: nanaki
For real, that would be one badass engine. If your gonna try and do a swap, I would go with a DOHC engine. Either the one with the S/C from the 03/04 Cobra or even a Mach 1. Forgot to mention, its gonna cost an arm and a leg to do the swap, so be prepared.
Old Feb 2, 2006 | 01:50 PM
mustangman02232
ORIGINAL: 01SilverGT
ORIGINAL: nanaki
ORIGINAL: nanaki
super coupe thunder tird
and you have to be single port to do the swap, pm cobra 232 he knows more then me on this.
