Electrical Question
Old Feb 16, 2006 | 04:42 PM
traveler's Avatar
traveler
I ♥ Acer
Default Electrical Question
04 Mustang - what would be a "keyed" hot wire? radio?....anyothers that can be easily found under the hood?
Old Feb 16, 2006 | 04:45 PM
03YellowPony's Avatar
03YellowPony
Default RE: Electrical Question
ORIGINAL: traveler
Radio..no. Headlights yes. Under the hood? Drill a small hole in the top of your positive battery terminal. A sheet metal screw, a crimp connector and some wire, and VOILLA!
Old Feb 16, 2006 | 04:50 PM
traveler's Avatar
traveler
I ♥ Acer
and that is a keyed hot wire.....???? not hot all the time just when I turn on the key????
What do headlights have to do with it?
Old Feb 16, 2006 | 05:53 PM
03YellowPony
ORIGINAL: traveler
****! Keyed? Damn. Sorry. I guess I should really read stuff! LOL
Radio is keyed, foglights are keyed, but there should be at least one keyed add spot on the fuse block.
Old Feb 16, 2006 | 06:04 PM
traveler's Avatar
traveler
I ♥ Acer
GTs come with fog lights and we have to install them. Is there an open fog light wire? Anyway thanks
Old Feb 16, 2006 | 06:23 PM
03YellowPony
ORIGINAL: traveler
Yea, but it's under the dash.
What are you trying to do?
Old Feb 16, 2006 | 06:26 PM
traveler's Avatar
traveler
I ♥ Acer
Put on Corvette yellow running lights and turn signals and Day Bright lights
Old Feb 16, 2006 | 06:35 PM
03YellowPony
ORIGINAL: traveler
Put on Corvette running lights and turn signals
EWWWWWWWWWWWEEEEEEEEEEEE!!!!!
J/k...put up pics when you get done.
Old Feb 16, 2006 | 06:38 PM
traveler's Avatar
traveler
I ♥ Acer
Should add 250 rwhp
Old Feb 16, 2006 | 06:41 PM
traveler's Avatar
traveler
I ♥ Acer
It will look totally wicked..they go in the fog light space...I'm having to do some manipulation and tinkering but also adding those "day bright" lamp kits which will be switched from inside the car like the fog lights...both will fit in the OEM fog light hole.
It would be very helpful if I had the OEM Fog light mounting plate dimentions and bolt sizes (two on each side)
