Rear Differential
Old Feb 18, 2006 | 11:29 AM
Dastang01's Avatar
Dastang01
Default Rear Differential
I was thinking about putting on a 7.5" rear differential. I have an 01 V6 stang. I was wondering if anyone has put one on an or if it is worth the money to invest in one??
Old Feb 18, 2006 | 12:05 PM
03YellowPony's Avatar
03YellowPony
Default RE: Rear Differential
ORIGINAL: Dastang01
You have a 7.5" rear dif already
Old Feb 18, 2006 | 12:14 PM
mustangman02232's Avatar
mustangman02232
do you mean 8.8? if you do not worth it right now unless you plan on getting alot of HP, i would however recomend 4.10 gears and a t-lok (limited slip)
Old Feb 18, 2006 | 01:26 PM
cobra232's Avatar
cobra232
Detroit truetrac limited slip differential
and it is worth the money
Old Feb 18, 2006 | 09:42 PM
mustangman02232
ORIGINAL: cobra232
its only worth it if you go with more then just basic bolt-ons. especially autos a t-lok will work just fine.
Old Feb 18, 2006 | 09:51 PM
beheivjer's Avatar
beheivjer
I still have the 7.5 in mine and will never change it but prob will change out the gears this spring.
Old Feb 19, 2006 | 11:16 AM
Dastang01's Avatar
Dastang01
Thanks..Where would be the best place to purchase the Detroit trutrac. I live like 30 min away from a summit racing, would that be suitable??
Old Feb 19, 2006 | 11:59 AM
beheivjer's Avatar
beheivjer
are you making alot of power or do you want to change just because the stocker will keep you going and you could put the money into something worth while for a real power increase, or a ride helper, springs shock struts, something like that
Old Feb 19, 2006 | 01:43 PM
cobra232's Avatar
cobra232
ORIGINAL: Dastang01
Summit carries them but you have to call them or type in the part# on their web search
summits part# is DTL-912A316 for $435
this place is chaeper at $412. they used to be $354 then $385 only about 6 months ago
http://www.drivetrainspecialists.com...duct-5407.html
the Detroit is the strongest differential made for the 7.5 except for the Detroit locker but the locker is not the best for street use
you will need a righmond gear install kit also summit's part# RMG-8310451
i would add gears at the same time as you do the differential but if you want the stock gears that's your choice. if you plan on adding gears in the future then just add them now. there is no sense tearing the rear apart twice
3.73's would be a great choice as would 4.10's
skip the ford T-lok. their clutches don't last very long (i went through 2 sets) and they are not very strong and have been known to break with stock power and sticky tires on 5spds
Old Feb 19, 2006 | 02:00 PM
Dastang01's Avatar
Dastang01
Thanks for the info
