Throttle Body
Old Feb 19, 2006 | 11:38 AM
Dastang01's Avatar
Dastang01
Default Throttle Body
Does anyone know if a BBK 70mm throttle body is a good investment. Another question is that i have a Diablo tuner, would I have to reset my parameters before i would install the throttle body.
Old Feb 19, 2006 | 11:43 AM
03YellowPony's Avatar
03YellowPony
Default RE: Throttle Body
ORIGINAL: Dastang01
First off, BBK stopped making the 70mm. If you order one, you're gonna get a 65mm. Second, if you install it, you're gonna have to port the intake for the new T/B. Cus if you don't, you will actually lose a little power. Third, unless you have some decent mods, the T/B will be a waste of money. Fourth, No. The computer will "learn" the new parameters by itself. It usually learns in the first 15 minutes of running time. That's what it says in the BBK install instructions.
Old Feb 19, 2006 | 12:04 PM
Dastang01's Avatar
Dastang01
thanks.. What kind of mods do you consider decent. The only thing i have is a K&N air filter, Which i am really considering getting the CAI. And I have an exhaust sytem that is it, and the computer programmer, I am looking for new plugs and wires also.
03YellowPony
ORIGINAL: Dastang01
My mods are the bare minumum if you want to go with the T/B.
Old Feb 19, 2006 | 12:21 PM
Dastang01's Avatar
Dastang01
thanks for your help. Do you know by change what size the stock T/B is??
Old Feb 19, 2006 | 04:50 PM
03YellowPony
ORIGINAL: Dastang01
Either 56mm or 60 mm. I forgot.
Old Feb 19, 2006 | 04:53 PM
cobra232's Avatar
cobra232
ORIGINAL: 03YellowPony
ORIGINAL: Dastang01
60mm
94-98 are 56 from BBK
Old Feb 19, 2006 | 04:55 PM
cobra232's Avatar
cobra232
a nice set of adjustable 1.8 roller rockers will really smooth out the valvetrain and you will pick up about 5hp with them due to the 1.8's adding about .020" lift and reduced friction
Old Feb 19, 2006 | 04:56 PM
03YellowPony
ORIGINAL: cobra232
ORIGINAL: Dastang01
60mm
I knew it was one or the other. Thank you!
Old Feb 19, 2006 | 06:10 PM
traveler's Avatar
traveler
I ♥ Acer
60mm.....did you get my email?
