Engine clean up
Old Feb 24, 2006 | 04:41 PM
NewMexMustang's Avatar
NewMexMustang
Default RE: Engine clean up
what exactly do you have to cover up when you do that stuff?
Old Feb 24, 2006 | 04:45 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
probably should cover your nuts
Old Feb 24, 2006 | 04:59 PM
NewMexMustang
Ha, already got that COVERED![8D]
Old Feb 24, 2006 | 05:00 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: NewMexMustang
Not much on our cars. The coil pack probably. On older cars, the dist. cap, and carb.
Old Feb 24, 2006 | 05:04 PM
NewMexMustang
doesn't the manual say to cover up the air filter, the alternator and the battery? i may be mistaken, just going off memory.
Old Feb 24, 2006 | 05:08 PM
03YellowPony
Maybe. I've used GUNK plenty of times. I never covered the battery, or alt. And on our cars, inless you have a CAI, the air filter is in a box. So, if you have a CAI, definatly cover it.
Old Feb 24, 2006 | 05:10 PM
tictac's Avatar
tictac
so, there is no problem with giving your engine a bath (using a power sprayer, for example)?
Old Feb 24, 2006 | 05:13 PM
NewMexMustang
ORIGINAL: 03YellowPony
Cool, so really you don't need to cover anything up exept the filter.
Old Feb 24, 2006 | 05:31 PM
03YellowPony
ORIGINAL: tictac
I DON'T recommend using a power washer. Just spray it down with GUNK and rinse off. Make sure the engine is warm, but not at operating temp.
EDIT
Just don't rinse it where a cop might see you. Some places frown on putting haz mat into the storm drain, or in the ground.
Old Feb 24, 2006 | 05:39 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
I'd be scared to use a pressure washer too. too much chance that pressurized water will find it's way somewhere bad.
