Are these safe?
Old May 14, 2007 | 07:26 PM
  #81
v6stang07's Avatar
v6stang07
Default RE: Are these safe?
i havnt really noticed any power difference but i think my mileage was better
Old May 14, 2007 | 07:30 PM
  #82
defconfire's Avatar
defconfire
I think i may have lost mileage but i also poured a s***load of acetone in
Old May 14, 2007 | 07:33 PM
  #83
v6stang07's Avatar
v6stang07
that was ur problem, 3 oz per 10 gallons
more isnt always better
Old May 14, 2007 | 07:37 PM
  #84
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Well I ended up doing too much hard driving to see a mileage increase. Mine was down, but it was down like it normally would have been. I know there's no way to gauge it when you do that so I'm gonna try it again until I either see better results or burn through that 32oz container I got.
Ryan
Old May 14, 2007 | 09:59 PM
  #85
MustangMike2001's Avatar
MustangMike2001
Does this look like the right stuff? It dosn't say 100% anywhere but it was the only kind they had at Lowes.
Old May 14, 2007 | 10:00 PM
  #86
RyansQuick6
Reverse Gear Member
Yup, look on the back, the only ingredient is the chemical formula for acetone.
Old May 14, 2007 | 10:09 PM
  #87
MustangMike2001
Ok yeah I see it. What isan easy way to measure out three ounces?
Old May 14, 2007 | 10:55 PM
  #88
defconfire's Avatar
defconfire
Mesuing cup is the easiest way. Or you could do what i did and pour 1/4 the F&*%ing bottle in your tank and see what happens... mileage went down
Old May 14, 2007 | 11:14 PM
  #89
Top Gear's Avatar
Top Gear
I almost need a fill up I'm going to wait till my needle is on E first. What's a good brand name of acetone to get? And how do i put it in the gas tank do I use a funel? Also Would it be better to put the acetone in first then fill up or fill up then add acetone?
Old May 14, 2007 | 11:21 PM
  #90
defconfire's Avatar
defconfire
I think your best bet is to put the acetone in at the pump and then fill up the tank (it mixes better). As for a brand I think they should all work about the same I bought mine at Lowes hardware.
