decklid vinyl
ORIGINAL: Cmpfreak88
When you put it on can you take some close-up pics? I know some people say it doesn't look that great close up no matter how good you try and put it on... I'm not sure whether I should spray paint the decklid or not... Sounds scary, haha
ORIGINAL: hpwrestler220
DO NOT spray paint anything on ur car unless its small or very thin..if you try to spray paint a large piece, it will not come out nice... some areas will be darker and such. get what im saying??? unless you are the best spray painter in the world [8D]
ORIGINAL: laserred38
You're going to need to remove your 232 emblem. Make SURE you use a micro-fiber cloth when smoothing out the bubbles. If you use paper-towels, it will leave swirl-marks (found that out the hard way...).The flat black will make the bubbles less noticeable. It took me about an hour, but I took my time. Either go from the middle piece and work your way out, or start with both corners and work your way in. Don't go from left to right or right to left..it will be harder to get everything aligned. A heat gun/blow dryer will help to curve the pieces...
Thanks for the advice, I will probably do it from the inside out
ORIGINAL: nocompetition04
well I just couldn't wait any longer. I have seen too many pics of stangs with it on em'. I just had to order it today in flat black off eBay for $35 shipped... can't wait for it to come in!
I think it's gonna really make my car stand out
. Next is either some gt side scoops or the 18" chrome svt cobras... and some 15 or 20% window tint.?
Thanks
Oh, and the difference between GT and V6 Side scoops is the GT ones... they come all the way up to the door and they're not as flat up against the body...
That's a GT Scoop
