New Edge Sixxer Question
Old Oct 26, 2007 | 06:58 PM
NYstang's Avatar
NYstang
MF Staff Snitch
Default RE: New Edge Sixxer Question
pretty sure theres a 800hp sixxer running a normal 3.8 block. dont the 4.6's split at 450?
Old Oct 26, 2007 | 08:36 PM
SilvrStang's Avatar
SilvrStang
Dont underestimate people. 3.8 is a strong block.
Old Oct 26, 2007 | 08:51 PM
Xemeth's Avatar
Xemeth
But the rods and pistons are weaker than the 4.6. How come you can safely go to about 300ish rwhp on a V6 at around 11 psi of boost and that being considered the "safe" level, when you can go to about 400 rwhp on a 2v 4.6 and be in the considered "safe" level. Sure, there's some 3.8's that are well into the 400's, but those people are on borrowed time. I'm not saying the 3.8 is a weak motor. The block and crank are ****in' amazing. But those are useless if you snap or bend your rods or shoot a piston through your heads.
Not bashing the 3.8, just trying to set in some sort of reality to those of you who think the 3.8 is bulletproof to the 4.6.
Oh, and about the 3.8 taking to boost better than the 4.6, it's about the same. A boosted 3.8 at around 9 psi will bring it to about 250ish rwhp give or take. From 160 average rwhp stock, that's about 90 hp. A 4.6 2v will go from about 230 rwhp stock to about 340-350 rwhp on average with 9 psi. That's 120 rwhp gain. A lot can do with the tune, so let's just call it equal. But the 3.8 doesn't like boost more than the 4.6.
Old Oct 26, 2007 | 09:56 PM
SilvrStang's Avatar
SilvrStang
ORIGINAL: Xemeth
Like the qoute said "There is no replacement for displacement " but Im just saying 3.8 is hell of a block for the powr it can handle without being modified. Justin at VMP is runin TT on his 3.8 with stock internals. Car is runin 10s in a 1/4
Old Oct 26, 2007 | 10:08 PM
Xemeth's Avatar
Xemeth
ORIGINAL: SilvrStang
ORIGINAL: Xemeth
I know Justin is running that power. But that's one person. Take 9 other people with the same stuff done to their cars and see those 9 have blown motors after a few 1/4 passes.
I'm just saying that the 3.8 motor isn't stronger than the 4.6. The block is, but the block is useless without the internals.
Old Oct 26, 2007 | 10:17 PM
fiad06's Avatar
fiad06
Whenever the debate between 3.8 and 4.6 comes in Justin is always brought into this.
Old Oct 26, 2007 | 10:24 PM
Xemeth's Avatar
Xemeth
ORIGINAL: fiad06
Justin and Matt Neuharth (sp?) are always the sixer fallbacks. It's kind of annoying with the "Well he has this," or "His car can do this".
Old Oct 26, 2007 | 10:31 PM
SilvrStang's Avatar
SilvrStang
ORIGINAL: fiad06
Oh let me give you some more names then, Mikael,Jay and so forth just that they dont get much publictiy as Justin and Matt
Old Oct 26, 2007 | 10:38 PM
Xemeth's Avatar
Xemeth
ORIGINAL: fiad06
So go forth...
Old Oct 26, 2007 | 11:05 PM
l_shizzle_l's Avatar
l_shizzle_l
ORIGINAL: Xemeth
And the interternals are useless without the block. Both of them have thier share of disadvanges, but they respond to bolt on's basically the same.
