lowering
Old Aug 3, 2008 | 06:51 PM
crbakp10's Avatar
crbakp10
Default lowering
i want to lower my car but i also want rims, which should be done first? would a different rim size affect the car if has already been lowered?
Old Aug 3, 2008 | 08:43 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: lowering
Pretty much anything will work, I have 18x9 in front and 18x10 rear, I also run 17x10.5 rears on 315's.
Old Aug 3, 2008 | 10:27 PM
crbakp10's Avatar
crbakp10
yea but should i wait to get rims before lowering or would matter if it was lowered before i got rims
Old Aug 3, 2008 | 10:40 PM
RyansQuick6
Reverse Gear Member
No, it doesn't matter.
Old Aug 4, 2008 | 12:43 AM
v6stang07's Avatar
v6stang07
i got rims then a month later lowered my car
Old Aug 4, 2008 | 05:34 PM
mcfarway's Avatar
mcfarway
Your sig shows the 16" stockers, they're a nice compromise of rotating mass vs. low profile tires. My car had the 15" stockers ... nice rims but waaaay too much sidewall for cornering. I went with the lowering (springs, shocks/struts, isolators) first (best bang for the buck -handling/braking/cornering performance and better stance/appearance). Just my opinion (everybody's got one).
Old Aug 4, 2008 | 05:45 PM
crbakp10's Avatar
crbakp10
well whenever i do get them i would be getting them mainly for the appearance more than the performance. as of now i want my to look good and ill work on performance things later when i have more money.
Old Aug 13, 2008 | 03:28 PM
baddog671's Avatar
baddog671
1" larger wheels will raise the car's clearance .5" but also fill the wheel wells better. So if you go from like 16 to 18", you'll raise the car 1". I'd get the new wheels and then access your lowering needs...
Old Aug 13, 2008 | 06:44 PM
RyansQuick6
Reverse Gear Member
Uh, NO!
It's the diameter of the tire that affects a change in ride height. A 15" wheel and an 18" wheel can have the exact same tire diameter, which is how it's supposed to be done.
So it has no bearing on drop.
Old Aug 13, 2008 | 07:47 PM
LilRoush's Avatar
LilRoush
Beat me to it.
