Hard start and knocking
Old Feb 3, 2009 | 08:26 PM
eli98's Avatar
eli98
Originally Posted by Matts 85 LX
Sorry wasnt paying attention. Meant CEL
Matthew
No worries.
Soooo, out came the engine. I plasti-gauged the mains and rods, mains at .004, rods .005. Is this within tolerance? I don't have a manual, and am not keeping this car (Need a family vehicle) so I am not wanting to buy one for the next guy. I also am not going to slap it together, so that he gets the $h1tty end of the stick. What else makes a knocking sound at low idle, but goes away at under even the lightest throttle? Would piston slap sound like a knock? What else could knock in this engine? I've heard that they run a balance shaft? What and where would I find a balance shaft? Is that simply a crank with the Harmonic Balancer on it?
I've run out of ideas. I'd set it on fire if it wasn't in my garage.
How do I test for piston slap?
Old Mar 19, 2009 | 08:31 AM
DBovine's Avatar
DBovine
Did you get any further with this? I think Im developing a knocking sound on my 02, but it is also only on low idle, as in when I am in neutral with the parking brake on
Old Mar 19, 2009 | 11:50 AM
ESG-642T's Avatar
ESG-642T
Buyer Beware
So does it still knock?
Old Mar 19, 2009 | 05:39 PM
eli98's Avatar
eli98
Mine was the plugs. Check your spark plugs before pulling the engine. Infact check anything you can think of, that is easy maintenance before pulling your engine. I think I may have broken a wire on the install and now the check engine light is on, and says that I have a bad heater circuit in my o2 sensors.
Old Mar 19, 2009 | 07:59 PM
ramoyer1's Avatar
ramoyer1
lol man you got a mess on your hands........
Old Mar 23, 2009 | 04:22 PM
eli98's Avatar
eli98
Thanks for those words of encouragement!
Old Mar 23, 2009 | 04:59 PM
mudvayne1's Avatar
mudvayne1
Pull the engine and the transmission because of a tiny knock? Thats like doing brain surgery without diagnosing the patient.
Good luck.
Old Mar 23, 2009 | 05:08 PM
SuPa StaLLiOn 7's Avatar
SuPa StaLLiOn 7
This doesn't pertain to this topic, but sometimes when I accelerate I get a metallic-sounding sound, like a drawn out metal screech or something... It's hard to explain, but it's not very loud... I hear it and know it's there. Any ideas on this "great" explanation I just gave?
Old Mar 23, 2009 | 05:13 PM
Fink's Avatar
Fink
Brakes contacting the rotors a bit?
Old Mar 23, 2009 | 06:56 PM
SuPa StaLLiOn 7
Hmm, I should get my brakes checked... Haven't had them checked since I got the car two years ago, could be down towards the end... Definitely something I should get looked at... How can you know if your brakes are worn down by just looking at them?
