lower intake manifold manual air control valve setup
Old Dec 28, 2019 | 03:23 PM
catg's Avatar
catg
Default lower intake manifold manual air control valve setup
2002 3.8 L v6. I cleaned the lower intake manifold and removed the manual air control sensor unit. After replacing the unit and added new bushings, the valves are not set the same. when one is closed the other is gapped about 1/8 inch
I will adjust the rods to make it match but I did not know if the side that is gapped is correct or the one completely closed.
thuxel
Sep 4, 2019 01:01 PM
KillaKobra1
Maryland Regional Chapter
Apr 10, 2019 07:54 PM
Luis-f
3.7L V6 Technical Discussions
May 26, 2017 12:07 PM
Rey Felix
Jan 12, 2013 02:16 PM
95fiveO
Mar 1, 2006 11:25 PM
