HID PROBLEMS HELP!!!!!!!!
Old 03-08-2006, 09:29 PM
RedAlertlb
RedAlertlb's Avatar
Default HID PROBLEMS HELP!!!!!!!!
I have had my kit for a couple weeks but just have never installed it. finally when i connect it everthing was working good until i started the car. When i start the car it was be fine for about 2 seconds and then they flicker like strobes and the relays make a clicking noise. Can anyone help me.....or is this just a waste and i will have to buy a new kit.
RedAlertlb is offline
Old 03-08-2006, 10:06 PM
RedAlertlb
RedAlertlb's Avatar
Default RE: HID PROBLEMS HELP!!!!!!!!
can some one PLEEEEEEEEEEEEEEAASE HELP please
Old 03-08-2006, 10:18 PM
afixer
afixer's Avatar
any info on how you installed them?
afixer is offline
Old 03-08-2006, 11:00 PM
RedAlertlb
RedAlertlb's Avatar
Both power wires are connected together to the battery with a 20A inline on both of them. Both power wires go into the 30A relays. Off the relays is the ground , the black and white wire to the stock harness and wires going to the ballast. The ballast connects to the igniter and to the HID bulbs
Old 03-08-2006, 11:02 PM
RedAlertlb
RedAlertlb's Avatar
i checked he voltage where the stock harness connects to the wires off the relays and the volt is like 12.4 when the car is off but when i start the car is just goes crazy and jumps all over the place any way to stop it?
Old 03-08-2006, 11:27 PM
Torch_Vert
Torch_Vert's Avatar
From a HID vendor website:
Both HID bulbs keep flickering and making clicking noise.
Reason: 1. See whether the HID bulbs have been connected to the ballasts correctly and tightly. 2. See whether the batteries of the car is too old or almost empty. 3. If your car's low beam has daytime running lights, make sure to disable that before installing the HID kit.
Torch_Vert is offline
Old 03-08-2006, 11:29 PM
afixer
afixer's Avatar
im thinkin the smartbox must have somkind of conflict. try getting a relay and hook the light wires to the coil side then ground your kit and use the relay as a passthru for power to your kit.
afixer is offline
Old 03-08-2006, 11:30 PM
afixer
afixer's Avatar
good find torch
afixer is offline
Old 03-08-2006, 11:55 PM
TNT1968
TNT1968's Avatar
Maybe you should up the guage on the power wires. How did you attach the power wires to the battery? Jump the car and see what the lights do. Check the water in the battery first.
TNT1968 is offline
Old 03-09-2006, 01:45 AM
RedAlertlb
RedAlertlb's Avatar
ill check the water in the battery in the morning and then try again
Quick Reply: HID PROBLEMS HELP!!!!!!!!
