Clear corners
Old Apr 5, 2006 | 07:17 PM
05 Silvertible's Avatar
05 Silvertible
Default Clear corners
My clear corners should be here tommorow...didnt someone have instructions posted on how to get to them to change them out? I thought it was easiest to go throught the fenderwell but after looking there today Im not sure! I ran a search but didnt find what I was wanting. anyone ??
Old Apr 5, 2006 | 07:41 PM
cstigger04's Avatar
cstigger04
Default RE: Clear corners
It real easy, 1st turn the wheels toward the side you are doing first. 2nd the inner fender panel should be losened, you do not have to remove it just take the screws out of the front part, its two peices. 3rd raise the front end up its alot easier if you do with the car in the air a few inches. Always use jack stands to support your car so you don't get smushed like a bug. 4th look up under the bumper, on the outside edge you will see two white fastners that you must squeeze will gently pushing from the outside of the bumper on the lense. 5th gently pull it out of the way after disconecting the light sockets and its free. install is the reverse. it took about 15 min/ side on mine and it looks 1000% better. put the factory bulbs back in they llok better than the sup[plied yellow ones unless you go and get the stealth bulbs wich look clear ubtil you light them up then they are yellow. good luck.
Lethaldosage423
Oct 19, 2015 12:12 AM
b8checker
Oct 8, 2015 12:55 PM
fastbackford351
Oct 1, 2015 12:24 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 8, 2015 11:50 AM
