Storage
Old Apr 12, 2006 | 04:16 PM
mtbker29's Avatar
mtbker29
Default Storage
Hey everyone my job is sending me to the Philippines in August for about 30-60 days for training. Just curious to see if I needed to do anything with my car other than disconnecting the battery while I'm gone.
Old Apr 12, 2006 | 04:18 PM
Trill Gear Head's Avatar
Trill Gear Head
Default RE: Storage
I'm thinking drain oil and gas?
Old Apr 12, 2006 | 08:14 PM
WindVeil05DropTop's Avatar
WindVeil05DropTop
Default RE: Storage
No, don't drain the oil or gas.... Draining the oil would be terrible on the engine, it would dry out.
I would run the gas down to maybe an 1/8th tank.
Then when you get back, do an oil change and fill the tank. Should be fine after that. Don't know if you really need to disconnect the battery, it may die anyways without being run for so long.
Old Apr 12, 2006 | 08:16 PM
blackfoot's Avatar
blackfoot
Default RE: Storage
lmao hes only gone for 30-60 days.... lol just park it and hide your keys lol
Old Apr 12, 2006 | 08:18 PM
blackfoot's Avatar
blackfoot
Default RE: Storage
id leave your battery connected for the short term.. incase some punk wants to try and take you car, once he opens the door or moves the window, your horn will start going off
unless your parking inside
Old Apr 12, 2006 | 09:22 PM
mtbker29's Avatar
mtbker29
Default RE: Storage
Thanks everyone for the information
Old Apr 12, 2006 | 10:11 PM
Fig06's Avatar
Fig06
Default RE: Storage
That short of a period should be no problem. I do recomend filing the tank. The more gas in the tank the less chance of condensation forming and adding water. You could also add a bottle od Sta-Bil ( SP ? ) You can get it in auto stores. It reduces the chance of water build up. I used it on my boat all the time and it was laid up from October to April. Never had a problem getting it running.
Oil change when you get back.
Old Apr 12, 2006 | 10:21 PM
blackfoot's Avatar
blackfoot
Default RE: Storage
im not gonna lie.. my cars been sitting for 5 months... i took her out.. started no problem. i didnt even disconnec the battery, or put fuel stabilizer in the tank.. i started her up and drvoe her out.. of course the rust onthe rotors had to be owrn off, and i had to clean the rims after to get the brake dust off... now im just rollingup on my 5000km oil change target.. todays oils arent like they used to be... if i did a test on the oil in my engine right now it would still be a go for another 4000km probobly.. thats why GM has the oil sensors in the oil pan that measures viscosity.. soyou wait till it tells you to change the oil
Old Apr 13, 2006 | 11:28 PM
Wicked Pony's Avatar
Wicked Pony
Default RE: Storage
I stored my 03 Monte Carlo for 4 months and I unhooked the battery and had a full tank of gas. It started right up after I hooked up the battery. Then I changed the oil.
Old Apr 13, 2006 | 11:34 PM
chrisc's Avatar
chrisc
Default RE: Storage
off topic: what area are you going to? my grandparents are living there
