Push Button start
Old May 1, 2006 | 02:41 PM
Furinox's Avatar
Furinox
Default RE: Push Button start
Just curious, why would you want a push button start if you still have to put the key in?
Old May 1, 2006 | 02:53 PM
90lxstang's Avatar
90lxstang
ORIGINAL: Furinox
Fun / coolness factor. Plus it just looks cool
Old May 1, 2006 | 03:12 PM
stupidassdrummer's Avatar
stupidassdrummer
exactly its cool looking. its something ive always wanted. It also impresses passangers
Old May 3, 2006 | 01:24 AM
blazen351's Avatar
blazen351
I ♥ Acer
I've decided to do this to my car. I ordered the illuminated kind with a blue button. I just ordered it and am REALLY hoping it doesn't look cheesey when all is said and done. Should be here in a couple of days so I can install it this weekend. Mod number 2!
Old May 3, 2006 | 01:28 AM
gabeh1018's Avatar
gabeh1018
i recently just replaced my stock headunit with a ddx-6019 and installed an amp and sub and ran all the wires myself.... is the push button/ignition relatively simple to install???
Old May 3, 2006 | 01:30 AM
blazen351's Avatar
blazen351
I ♥ Acer
I'll know for sure in a couple of days, but from what I've read so far it doesn't look like it should be hard.
Old May 3, 2006 | 01:47 AM
whatdaproblemis0's Avatar
whatdaproblemis0
ORIGINAL: Furinox
Im not good with cars but from what i read when you start the car by turning the key you will never have the same crank or firing when the car turns on, with this start button you have the same consistant crank everytime , Im not sure how to explain it.
Old May 3, 2006 | 02:39 AM
Harry_F's Avatar
Harry_F
is there a way to make a push button that i dont have to like put the key in that would be the best.
Old May 3, 2006 | 03:14 AM
scheetz83's Avatar
scheetz83
ORIGINAL: Harry_F
ur gona have to put the key in to unlock the stearing wheel
Old May 3, 2006 | 04:01 AM
blazen351's Avatar
blazen351
I ♥ Acer
Is unlocking the steering wheel a mechanical action from turning the key, or is it an electronic action when you turn the key? if it's electronic, there should be a way to bypass it so the key is not needed, problem with that though is that anybody could drive your car off after breaking a window out...might have to explore it a little anyways just to see
ORIGINAL: scheetz83
ORIGINAL: Harry_F
