IPOD FM Transmitters
Old May 9, 2006 | 08:21 PM
Titostang's Avatar
Titostang
Default IPOD FM Transmitters
hey, i need an fm transmitter for my car, and i cant use the big arm ones because our adapters are up high, and i have a manual so i wanted on that just stuck out like 3 inches and was placed right where the adapter is. i hate having the chord one because i dont like it in my cupholder adn the chord allways around the gear shift. just looking for waht adapters yall have. thanks!
Old May 10, 2006 | 01:38 AM
chidrock's Avatar
chidrock
Default RE: IPOD FM Transmitters
Mine's hardwired on. It really is better than the FM transmitters. I used to have this one, and it was pretty good: http://www.bestbuy.com/site/olspage....=1124432781049
If you're interested in getting it plugged into the aux input, here you go:
http://www.logjamelectronics.com/piefrd04aux.html
http://www.logjamelectronics.com/blitzuii.html
Old May 10, 2006 | 04:47 AM
Stewart's Avatar
Stewart
JUst double checking, it looks like if I wanted to I could wire it into the glove box. Is there enough wire to allow me to have it sitting in my cup holder when I want it out and tuck the adaptor away in the glove box when not in use? Also did you install that yourself or have someone do it?
Old May 10, 2006 | 11:13 AM
chidrock's Avatar
chidrock
I had it done because I didn't want to mess with tapping it into the power socket wiring. If you can do that, it's not too hard to install. It's just a matter of taking apart the console. The adaptor should plug right into the shaker's aux input. If you don't want to mess with the power, you could get a headphone adapter instead of the blitzsafe part. That just charges the ipod while you're listening to it & 20 minutes after you turn the car off.
The wire on the blitzsafe was pretty long, so you should be able to do that w/o a problem. If you don't use it, just try to get a headphone adaptor with a longer cord.
Old May 10, 2006 | 08:28 PM
LesteR723's Avatar
LesteR723
hardwire it. I'v owned 3 fm transmitters, the best one- obviously the most expensive- is still not all that good. Volume sucks, its scratchy all the time, cant go too loud, gets Serius interference and its just bad news.
lincolnshibuya
Oct 6, 2015 08:45 AM
fso119
Sep 23, 2005 07:16 PM
tcuallstar
May 28, 2005 03:55 AM
CharcoalGT
May 27, 2005 05:27 PM
