Burnout
Old May 16, 2006 | 07:12 PM
chipschwab's Avatar
chipschwab
Default Burnout
Went to do a burnout before i dragged at a local strip. I dont have t-lok yet. The car vibrated and bounced all over the dam place. Could this cause any future problems? Im sure it could cause rattling but im never doing it again till i get the t-lok. It vibrated sooo bad you have no idea. Everything was fuzzy it was vibrating so bad. Anyone else done this?
Old May 16, 2006 | 07:25 PM
Jimp's Avatar
Jimp
I ♥ Acer
Default RE: Burnout
It's called wheel hop. You can fix that by replacing the stock lower control arms(LCAs). I really like these:
http://powerhouse411.com/catalog/ind...&products_id=1
StickDriver's Avatar
StickDriver
Default RE: Burnout
No, that sounds horrible.
Old May 16, 2006 | 09:12 PM
chipschwab's Avatar
chipschwab
Default RE: Burnout
thanks jimp
Old May 16, 2006 | 09:25 PM
sonicblue05's Avatar
sonicblue05
Default RE: Burnout
guessing your Auto?
if you break em loose fast enough it wont do it,its because the tire is still trying to grip its not spinning fast enough. (i think)
manual only doesit if you dont give it enough gas, if you dump clutch at 3000 or so it wont do it.
Old May 16, 2006 | 10:48 PM
rygenstormlocke's Avatar
rygenstormlocke
Default RE: Burnout
ORIGINAL: Jimp
As Jimp would say "this is the correct answer". I got the powerhouse LCA's as well. Can't go wrong with Powerhouse. [sm=youreright.gif]
Old May 16, 2006 | 11:11 PM
ricklmesa@cox.net's Avatar
ricklmesa@cox.net
Default RE: Burnout
I got them too but I got hold off on the install.
Old May 16, 2006 | 11:22 PM
chipschwab's Avatar
chipschwab
Default RE: Burnout
Its a manual and i dropped the clutch at about 3-4k because i was already rolling at about 5 mph
Old May 17, 2006 | 12:07 AM
paulboy16's Avatar
paulboy16
Default RE: Burnout
my manual burns real nice... then only thing i can even see it being is half spinning half traction making it shudder... dus it do it EVERYtime?
Pauly
Old May 17, 2006 | 12:41 AM
Harry_F's Avatar
Harry_F
Default RE: Burnout
Yes, the TCS is controlled by your anti-lock brakes if you turn it off then you will do a clean burn out (once you get the tires spinning) if you leave it on its just burning up your brake pads.
