Going to the Track ...need direction....
Hello All!!!!
I am thinking of going to the track next week to see what my pony can do.... This Maryland Track I am new at this and need some direction.
a) My ride is not S/C or Turbo..... Do they put you against a class of similar power?
b) What equipment will I need? .....Safety for Driver ....Car Equipment......
c) I don't expect to win any heat, but I want to experience the ride....Any tips?
Thanks....
Thanks....
Man, I need to hit capitol!!! Too many members here go to that track. Ok, my answers below.
No, if it is test and tune you just run with everyone else.
Depends on the track, but I would invest in a snell2000 helmet. Most tracks don't require helmets for cars slower than 12's. Call the track and find out the what thier rules are, but I would get a helmet. Scrming and I got the Gforce open face helmets, easier to wear when its hot out.
-turn od off
-what tires are you running? pneros, put the rears at 30psi
Here is a link to some good write ups:
http://american-speed.com/collective...splay.php?f=10
At the top is some sticky's that I found helpful when I was a newb and technially, I still am LOL.
ORIGINAL: tino
Hello All!!!!
Hello All!!!!
ORIGINAL: tino
ORIGINAL: tino
Here's everything you need to know your first time out...
http://american-speed.com/collective...hread.php?t=63
To more specifically answer some of your questions...
a) They try and line you up against cars with similar capabilities, but it's sometimes the luck of the draw. For instance, my first time at the track, I had 3 runs against 3 different Mustangs. A 95-98 GT (blew 'im away), a Cobra (he blew me away!) and a 99-04 GT (it was close, but he edged me out).
b) Just the safetly equipment already in your car, such as seat belts. Most tracks require a helmet only if your trap speed is below a certain point. If your stock and close to it, you probably don't need one... but, check your track's rules. And, most tracks require you wear long pants and shoes.
c) See the link above! And, drive like ya stole it!
ORIGINAL: tino
Hello All!!!!
Thanks....
Hello All!!!!
Thanks....
Awsome Guys!!!
Thanks, I'll read over the links....
About the OD I have a stick.... Also being mostly stock (sort of
) I don't think I'll get to 120mph....(right?) so I shouldn't take the limiter off?
TCS off?
) I don't think I'll get to 120mph....(right?) so I shouldn't take the limiter off? TCS off?
ORIGINAL: tino
Awsome Guys!!!
TCS off?
Awsome Guys!!!
Besides that, don't get nervous and remember its just for fun. Don't worry about r/t your first couple of runs, your clock doesn't start till you pass the line anyway. Just get your launch down, that's the most important thing.
ORIGINAL: jericho73
Since we are on this topic of tracks, I always wondered. Has anyone seen a car get pretty damaged with someone being nervous behind the wheel. I ask because I know that I would be nervous as hell and most likely destroy my car.
When using my stock BFG's i put the tires between 25-30 PSI....my best times were @ 27psi in the rears, keep ur fronts @ the stock 35 psi you need as much air as you can get up there...And yes do turn off your OD so you dont go into 5th gear cuz u will lol. I noticed a couple tenths diff
