Quick help pls Caliper temp range
Old Jun 23, 2006 | 05:26 PM
tino's Avatar
tino
I ♥ Acer
Default Quick help pls Caliper temp range
I am just about to paint my calipers, found some heat resistant paint to 500 degrees..... I am not sure if our caliper can get hotter than that under heavy (traffic) breaking.
Any Ideas?
Old Jun 23, 2006 | 05:39 PM
Goliath's Avatar
Goliath
Default RE: Quick help pls Caliper temp range
if there is a walmart near you (I'm sure there is) check out the automotive section for "Duplicolor brake caliper paint kit" or something along those lines, it has the high heat paint that you'll need to paint the calipers.
Old Jun 23, 2006 | 05:50 PM
tino's Avatar
tino
I ♥ Acer
Thanks the store was out of my color.....
I found engine paint in the correct color and it resists heat to 500 F...... Looking on line dot 4 brake fluid boils at 446 F .....
I do not think I will get that hot unless I go to circuit racing for 100 laps.
Old Jun 23, 2006 | 07:18 PM
paulboy16's Avatar
paulboy16
try autozone, pepboys, discount parts they all carry the same stock, try reading the caliper paint box and see what THAT paint stands up to.
Paul
Old Jun 23, 2006 | 07:22 PM
Fizzie06's Avatar
Fizzie06
500 I just read it off the internet
UNLESS I LOOKED AT THE WRONG PAINT i WILL POST WITH THE INFO
Old Jun 23, 2006 | 07:42 PM
Fizzie06's Avatar
Fizzie06
Just got off the phone with the Dupli-color tech hotline 1(800)247-3270
They informed me that the Heat resistance of the Caliper paint was rated for heat up to 500
I hope this helps.
Old Jun 23, 2006 | 11:55 PM
tino's Avatar
tino
I ♥ Acer
Thanks, that indeed confirms that the one I have will work as well..
Thanks a lot!!!
Old Jun 23, 2006 | 11:58 PM
Fizzie06's Avatar
Fizzie06
no problem
Old Jun 23, 2006 | 11:59 PM
paulboy16's Avatar
paulboy16
is it a spray can? if it is u gotta be a ****ing god with masking tape and paper LOL!!!
Paul
Old Jun 24, 2006 | 12:00 AM
Fizzie06's Avatar
Fizzie06
they have both a brush on and spray on thats what they said on the phone
