Justins Procharger Write Up
YES SIR
here are before and after DYNO's TOP shoould be the procharger stock canned tune and the second one is the VMPtuning dyno
[IMG]local://upfiles/33810/8AC268B2C1AE4B28AECA337CEBF5C35C.jpg[/IMG]
[IMG]local://upfiles/33810/D9959CC0D1B94D9CAC500E9C61DD8300.jpg[/IMG]
Army, Posted this on another board...but wanted to post it here as well.....
You got some good TQ on that setup, don't be concerned you didn't break the magic so-called 300HP marker, TQ wins races and I would take 312TQ/292HP over 312HP/292TQ.
So whats next for you, suspension, gears, LSD? 3.73's will help you into your boost range off the line, improve your launch and reduce your 60ft time. Thoughts?
yes i been emailing mike @ powerhouse in regards to suspenison product..
On the first I should be getting the following below .. and if I have enough the t-lok aswell
POWERHOUSE suspension pack CHE-8KT includes the Fixed Length Tubular Lower and Upper Control Arms, Anti-Squat Brackets, & K-Member Brace with Torque Limiters. .
Tubular Panhard Bar Brace CHE-6N
Double Adjustable Aluminum Panhard Bar CHE-6L
direct bolt aluminum drive shaft(possible safety loop0
But look for what I post on the 1st of augest... I could do heads but hell i woulda wasted time in driving to florida cause i would need a new tune and crap ...lol.. but iT IS drive line and suspension next for sure. then the wideband
__________________
__________________
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
