Jack Stand Location (Pics)
Old Jul 7, 2006 | 12:39 AM
05BlackPony's Avatar
05BlackPony
Default Jack Stand Location (Pics)
OK.. I know this type of thread has been disscussed, but would like some reassurance before I do a LCA swap.
I know where to put the jack when lifting (Pic 1)
But where do I place the jack stand when the floor jack is in the notch area?
Do I place it on the same "black metal" or the "green metal" ? (Pic 2)
Also, is a two-ton floor jack capable of lifting the car?
Sorry if these are some n00b questions.. I just don't wan't to damage the car..(or me lol)
Thanks
[IMG]local://upfiles/19936/E60CE74AF8C64B13A7B900C573A84813.jpg[/IMG]
[IMG]local://upfiles/19936/02B86E239DC04A3CBE0BDDD61B7AB932.jpg[/IMG]
Old Jul 7, 2006 | 02:50 AM
TheWatcher's Avatar
TheWatcher
Default RE: Jack Stand Location (Pics)
what kind of rims are those?
Old Jul 7, 2006 | 02:59 AM
05BlackPony
Stern ST-7 Hypermesh 20's
Old Jul 7, 2006 | 03:13 AM
workshop4ever's Avatar
workshop4ever
any place with metal that you have picture should be acceptable for jacking the car. The only thing you want to stay away from is really thin metal, and any plastics. Generally the areas closer to the center of the car are stronger metal. And yes, a 2-ton jack will left the car just fine.
Old Jul 7, 2006 | 03:15 AM
05BlackPony
ORIGINAL: workshop4ever
Thanks for your help! Can't wait to install them!
Old Jul 7, 2006 | 03:20 AM
paulboy16's Avatar
paulboy16
wait
the best thing is to jack up under the REAR DIFF on the flat part (not the cover) and then place ur jack stands under the frame rails (where u have ur jack in the first pic) then remove the jack thats under rear differential.
Paul
Old Jul 7, 2006 | 03:35 AM
05BlackPony
ORIGINAL: paulboy16
wait
Paul
Sounds good! I'll have to check and see the flat part you're talking about. I think my jack stands will fit perfect where the cut-outs are because they are U shaped.
Also I like this idea because I won't put stress on one side of the car then move to the other when jacking up.
Thanks Paul.
Old Jul 7, 2006 | 10:52 AM
Randys06v6's Avatar
Randys06v6
where did you buy them rims and how much were they?
Old Jul 7, 2006 | 11:19 AM
jaiasmit's Avatar
jaiasmit
ORIGINAL: paulboy16
wait
Paul
I'm pretty sure the manual says specifically NOT to jack the car using the rear differential. If for some reason the jack slips, you could do some major damage to the driveline components (axles, driveshaft, differential, etc...)
Old Jul 7, 2006 | 02:44 PM
05BlackPony
ORIGINAL: jaiasmit
ORIGINAL: paulboy16
wait
Paul
Hmm Its true in the manual that they don't suggest any jacking on the Diff.
Here are some fresh pics of the "flat part".
Good/Bad to jack there?
[IMG]local://upfiles/19936/E7F8CE64A4B942348340866B9077D369.jpg[/IMG]
[IMG]local://upfiles/19936/2D784451DFA04285AF67256B29E7FB18.jpg[/IMG]
