UnderDrive pulleys
Old Jul 14, 2006 | 11:11 PM
Horrific_Ending's Avatar
Horrific_Ending
Default UnderDrive pulleys
Ok so been searching on ebay and i see v6 underdrive pulleys and v8 underdrive pulleys. Dont really see a difference. so the question is will v8 underdrive pulleys fit v6's?
Old Jul 14, 2006 | 11:14 PM
rygenstormlocke's Avatar
rygenstormlocke
Default RE: UnderDrive pulleys
No they wont fit. Also, the UD pulley out on our cars shows no gain. I would go PHP Alternator Pulley, Scrming dyno'd it for 3-5HP gain. I have it installed on my car as well.
Old Jul 14, 2006 | 11:16 PM
Horrific_Ending
is a 3-5 hp gain really worth it tho?
Old Jul 14, 2006 | 11:17 PM
rygenstormlocke
When you are NA, every little bit helps. Its 170 bucks, up to you really.
Old Jul 14, 2006 | 11:39 PM
hamidlmt's Avatar
hamidlmt
I ♥ Acer
I've been holding off on underdrive pulleys just because it doesn't seem quite worth it. The PHP alternator pulley is the way to go though, instead of the over-priced ASP pulley. If I end up staying NA for another year, then they'll up their place in my list.
Old Jul 21, 2006 | 06:51 PM
Defiant's Avatar
Defiant
(possibly) foolish question... are these fabled PHP alternator pullies still available to purchase? A quick search on Google yielded nothing.
--=K
Old Jul 21, 2006 | 07:02 PM
rygenstormlocke
You have to call them directly to order it, that is what I did.
Old Jul 21, 2006 | 08:30 PM
User 113021's Avatar
User 113021
Aw man, I hate using phones. Internet ftw.
Old Jul 22, 2006 | 12:40 AM
05AV6's Avatar
05AV6
You know that is not entirely true. Doug dyno'd the ASP UD pulley on my 05 with an auto. The pulley showed a 4 RWHP gain and about 6 lb ft of torque. The UD pulley also reduces rotational mass , which I'm really surprised all you racers out there haven't realized, given all the chatter about aluminum drive shafts and the weight savings on that end of the drive train.The ASP UDP has been dismissed without so much as a run down the track. By the way the pulley is still on my car, I still say the engine revs and responds quicker. with the pulley installed. As I have stated before , I have had NO problems with the pulley, no charging problems or cooling problems, and this summer is HOT down here in Bama the A/C works fine. The pulley is a little expensive, but it is NOT snake oil.
Old Jul 22, 2006 | 12:43 AM
rygenstormlocke
Well I stand corrected, I feel bad now for posting it showed no gains. I thought that is what the write up said. I will go back and search on it. You have my apologies man.
