BOV
Old Jul 15, 2006 | 03:26 PM
bluhawkshockey31's Avatar
bluhawkshockey31
Default BOV
ok no one get on me for this cuz i dont know alot about f/i's so if this question is stupid then sorry. But if your using something like the x-charger or a vortech supercharger can u put on a bov? I thought they were only for turbos? Thanks guys
Old Jul 15, 2006 | 03:51 PM
bluhawkshockey31
Default RE: BOV
anyone?
Old Jul 15, 2006 | 03:52 PM
BlueStang6's Avatar
BlueStang6
Default RE: BOV
ORIGINAL: bluhawkshockey31
You're right in your initial thought that a blow-off valve is only for Turbos but since a centrifugal supercharger is, for the lack of a better description, a modified turbo it also benefits from a BOV. The valve is only used on F/I cars with a turbocharger or supercharger. When you are giving the car heavy throttle, there is a lot of pressure in the intake, and when you lay off the throttle suddenly, that pressure needs to be released. This is what the blow-off valve does.
On some cars this valve is tuned so you can hear it from outside the car. It makes a distinct "whooshing" sound when the driver lets off the gas suddenly.
Old Jul 15, 2006 | 03:58 PM
bluhawkshockey31
Default RE: BOV
so something like the x-charger being a roots type...it wouldnt work with one
Old Jul 15, 2006 | 04:06 PM
petepete's Avatar
petepete
Default RE: BOV
blowoff valve goes on your exhaust not charger so in theory it should work
Old Jul 15, 2006 | 04:10 PM
lilc1511's Avatar
lilc1511
Default RE: BOV
petepete please do not talk... you are incorrect... and bluestang was right
it is on the intake side... and the wastegate is on the exhaust side...
don't argue...
Old Jul 15, 2006 | 05:39 PM
petepete's Avatar
petepete
Default RE: BOV
my buddies sti has blowoff on exhaust pipes but whatever not gonna argue with someone who gets so mad over something small must be on your period
Old Jul 15, 2006 | 05:45 PM
8cd03gro's Avatar
8cd03gro
Default RE: BOV
a blow off valve is always on the intake side or it is completely pointless. The blow off valve's purpose is to release excess pressure once the throttle is closed. Once the throttle is closed, the boost coming from the turbo has nowhere to go, but backwards. This is very dangerous for your turbo because it can spin the blades backwards and jam or even damage them. With a bov, the blades can keep spinning between shifts, the boost just goes out the bov instead of back into the turbo. If the bov were on the exhaust side it wouldnt do anything at all. It would never even open because the pressure isnt great enough because there is enough flow through the exhaust. I dont mean to be mean, but if you think your buddy has an sti with a bov on the exhaust you are either mistaken, or lying.
Old Jul 15, 2006 | 07:10 PM
TorchV6's Avatar
TorchV6
Default RE: BOV
ha petepete your a fool hahaha that is called a wastegate on his exhaust side
Old Jul 15, 2006 | 07:21 PM
petepete's Avatar
petepete
Default RE: BOV
8cd03gro thanks for explanation as for torch and the other guy becaus ehe told me his bov is there i assume thats what it was dont have to get **** pants over it
