Weight Reduction
We're no fatty's but we're not light either. 3300lbs is a lot of sheet metal to push around.
What can we do to reduce weight?
Sure, take out the spare tire and jack, worth maybe 40lbs. CF hood maybe worth 7-10lbs? CF trunk lid worth another 10lbs or so. I only weigh 130lbs... so I'm not dragging the car down.
What have you guys done to put a dent in our power:weight ratio?
put dymag carbon fiber rims i need a test mule :P take out passenger seat gut dash take out ac and speakers gut anything in the interior that makes it nice and comfy thats just a start though. Take out airbag system
subframe from BMR
aluminum driveshaft
BMR radiator support sway bar delete.
those 3 would probably be worth about another 80 lbs
lightweight 15" weld xp wheels. like 3-6 lbs each. plus tires.
good for another 100 lbs+ and less rotating mass.
so do that with the CF hood and trunk, tire and jack, rear seat.... ur lookin at like 250-300 lbs.
aluminum driveshaft
ORIGINAL: fazm
subframe from BMR
aluminum driveshaft
subframe from BMR
aluminum driveshaft
those power seats weigh more than they need too, take out some motors and wires,and it sounds like 15 pounds a seat to me :P that new bmw z3 m3 thing has a can of fix a flat for its spare tire!!if that sounds dumb just get AAA. You could take apart your doors and put it back together after pulling out all the insulation , if you think the stereo only needs to be loud enough so you can hear it take out a few speakers ( those mini woofers in our doors gatta weigh something!!) Do you have a manual or auto matic?? if its an auto you could probly go without the whole emergency brake system(including e-brake brake pads), and hope there's no emergency. And not including the can of fix a flat you dont have to buy anything, you might even be able to sell some of it.
jar_are_red
Sep 24, 2015 07:03 AM
Sep 8, 2015 11:50 AM
