spark plug picture
Old Sep 12, 2006 | 02:35 PM
boss 244's Avatar
boss 244
Default spark plug picture
A few post back there were questions about my car running lean. Some wanted to see the old plugs so I scanned them. They are marked DF (drivers front), DM ( drivers middle), PR (passengers rear) etc...Anyway, as the car had 21k on it when I got it and had 30k when I took them out, it may not be applicable to whats going on. They are in rough shape, but that goes with the car being a ford fleet vehicle.
Another aside.. I got my SCT2 back from Alternative auto but forgot my C&L filter. I installed the 87 tune anyways and it wouldn't idle, not getting enough air through the S&B filter. I will put on the filter tonight and reinstall the tuner and see what happens.
[IMG]local://upfiles/41550/3F683E3CFFF74FA2AE16BBFC63510F14.jpg[/IMG]
Old Sep 12, 2006 | 04:30 PM
fazm's Avatar
fazm
Default RE: spark plug picture
those sure arent lean.
are those the ones before 30k? or the ones since then?
Old Sep 12, 2006 | 05:01 PM
boss 244's Avatar
boss 244
Before 30k, I would guess they are the original equiptment.
Old Sep 12, 2006 | 05:26 PM
fazm's Avatar
fazm
gotcha. have you pulled one of the newer ones to see how they look?
im going to be coming up on changin out my plugs soon, only because i want to run a different plug with the turbo.
Old Sep 12, 2006 | 05:30 PM
boss 244's Avatar
boss 244
No, I haven't, but I will this weekend when I install my LCA's and panhard bar. I'll take photos of them then. I'm curious to see what they look like myself.
Old Sep 12, 2006 | 05:31 PM
boss 244's Avatar
boss 244
What kind are you (Fazm) thinking of switching to? is their a reason besides hotter or colder?
Old Sep 12, 2006 | 05:36 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Lean would be more grey discoloring than what your seeing. What I see is Detonation...look at PM (Passenger middle?) and PR...that much black with the electrode itself looking 'clean' is detonation or too hot of a plug.
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
http://www.ngksparkplugs.com/techinf...q/faqread2.asp
Old Sep 12, 2006 | 05:49 PM
scrming's Avatar
scrming
ORIGINAL: Derf00
I believe are plugs are actually a "cooler" plug...
Boss, do you happen to have a laptop? or acces to one? You can hook your X-Cal2 up to the laptop (with the proper USB cable) and datalog the car and watch things like the knock sensor..
Old Sep 12, 2006 | 05:59 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: scrming
ORIGINAL: Derf00
detonation OR too hot of a plug is what I said. If you ahve a colder plug, then you have detonation. (Timing issue or wrong octane fuel - too low)
Old Sep 12, 2006 | 06:29 PM
boss 244's Avatar
boss 244
My laptop is 8 years old and won't run the Liveload, maybe ai should stop buying car parts and get a new laptop. But then those are the plugs that the car came with, and I didn't look at them before I modded the car. I know that the fuel used by ford was bad because the fuel filter was pouring out black crap.
