Windows
Old Dec 19, 2006 | 03:00 AM
NinjaMom's Avatar
NinjaMom
Default Windows
Going to get my windows tinted soon. On th 07 how do you keep them from rolling down when you open the door and rolling up when you shut it?
Thanks,
Old Dec 19, 2006 | 01:32 PM
enorym's Avatar
enorym
Default RE: Windows
Disconnect the battery with the doors closed.
Old Dec 19, 2006 | 02:40 PM
NinjaMom's Avatar
NinjaMom
Default RE: Windows
ORIGINAL: enorym
Ok, But when you reconnect the battery wouldn't it start doing it all over again? The place that tints my windows doesn't want you moving the windows for like 3 days...
Old Dec 19, 2006 | 03:12 PM
MrSandman's Avatar
MrSandman
Default RE: Windows
Look in the owners manual. It's in there.
Also... if they cure it properly.. you should not have a problem.
Old Dec 19, 2006 | 03:50 PM
grbrorng07's Avatar
grbrorng07
Default RE: Windows
Have them pull the door panels off and tint to just below the rubber piece. That is what they done to mine and no problem at all.
Old Dec 19, 2006 | 05:15 PM
NinjaMom's Avatar
NinjaMom
Default RE: Windows
ORIGINAL: MrSandman
Didn't see it....But atleast now I know it should be in there.
Thanks
Old Dec 19, 2006 | 06:07 PM
Archion's Avatar
Archion
Default RE: Windows
In the owners manual it tells you how to deactivate it for the icy seasons so it wont burn out the motor if the window is frozen. And if you disconnect the battery then you will have to recalibrate the window roll-up, says that in the same spot in the manual.
Old Dec 20, 2006 | 01:16 AM
samuraidad's Avatar
samuraidad
Default RE: Windows
one other item to look into has to do with the window molding. I understnd that the molding will scratch the tint. Some have suggested moleskin to prevent this problem. I am not sure if ford has a fix or not might want to check this out first thought so you do not waste your money
Old Dec 20, 2006 | 10:19 AM
FastLane034's Avatar
FastLane034
Default RE: Windows
I got my windows tinted, never bothered disabling it. I got a small amount of reflective chrome in mine, and it took a month to dry. That month I rolled my window down and up once, and open and shut my door a million times. The tint is still flawless, not a scratch on it. I wouldn't worry about it personally.
Old Dec 20, 2006 | 11:52 AM
NinjaMom's Avatar
NinjaMom
Default RE: Windows
My Nissan Armada scratched my window tint after awhile. I hated it.I hope Ford has fixed it, because I love to have my windows tinted, but I can't handle scratches.
