hurst problem.
Old Dec 22, 2006 | 07:22 PM
bluhawkshockey31's Avatar
bluhawkshockey31
Default hurst problem.
Ive had my hurst shifter in for 3-4 months now however i have had one problem with it all along. At about 3-4,000 rpm i get a metal rattling sound coming from the shifter? Any thoughts? It sounds like the 2 metal peices might be vibrating together? Anyone else had this problem and maybe a quick fix-it? Thanks
Old Dec 22, 2006 | 07:35 PM
Stangrunner06's Avatar
Stangrunner06
Default RE: hurst problem.
90 percent of Hurst owners have the problem. Hurst recommends a buffer between the shifter and handle when they are bolted up. Some guys use electrical tape, some a neoprene or silicone gasket. The problem is the die that punches the knurl sucks, so they don't match when you bolt them up. In time they loosen up and vibrate. They also recommend Loctite on the bolts, Blue preferably,but red will work also but a little tougher to unbolt. Hope this helps.[sm=icon_rock.gif]
carid
Jul 8, 2016 09:55 AM
firehorse02
Nov 16, 2015 11:28 AM
69Volunteer
Sep 30, 2015 10:39 AM
mdj89
Sep 23, 2015 08:49 AM
Webster454
Sep 7, 2015 04:59 AM
