Manual Trans Users....
Old Jan 11, 2007 | 05:14 PM
4LITER6's Avatar
4LITER6
Default Manual Trans Users....
The Hurst Shifter has to be in the top 5 Mods...................really worth the $$$, it's like night and day!!!
[sm=gears.gif]
Old Jan 11, 2007 | 07:44 PM
NickSezz's Avatar
NickSezz
Default RE: Manual Trans Users....
Thats part of my stage 3 work on the stang...next year....next year....
Old Jan 11, 2007 | 07:47 PM
8cd03gro's Avatar
8cd03gro
my birthday (february 14) = cai/tune + hurst
first day of spring = gears/locker
soon after = its a secret
Old Jan 11, 2007 | 10:22 PM
mustangman02232's Avatar
mustangman02232
any STS will make a difference, MGW is a little better cause it can be rotated
Old Jan 11, 2007 | 10:27 PM
volcom2218's Avatar
volcom2218
I was looking into the Hurst Shifter and now it seems like im going to purchase it.
Old Jan 12, 2007 | 12:01 AM
PennState's Avatar
PennState
how much are they!
Old Jan 12, 2007 | 01:59 AM
harlanb1's Avatar
harlanb1
4LITER6,
Adding a short throw shifter is going to be my first mod. I have been looking at the Hurst shifter, but I have been reading a lot of posts saying that rattles are a common problem with that shifter. Have you had any problems with vibration or rattle with your shifter?
Old Jan 12, 2007 | 02:01 AM
8cd03gro's Avatar
8cd03gro
you know, at first i was worried about that, but then i realized-
my car rattles so much already, i probably wouldn't even hear it. i need to fix some of these damn rattles.
Old Jan 12, 2007 | 10:25 AM
4LITER6's Avatar
4LITER6
ORIGINAL: harlanb1
4LITER6,
Hello harlanb1,
The rattle comes from where the shift handle shaft connects to the shaft that come of the shifter, apparently what I gathered is that in time they come loose, both parts are threaded, which is connected with fine thread bolts that uses a allen wrench, they supply with two star type washers which are to used on the head side of the bolt, I went ot Home Depot and got two fine thread 3/8 nuts and used the washer on the other side, not the head side, tightened the nuts against the washers..................I can not see the handled coming loose using this technique...................I have only used this new shifter for one day.....................if it rattles............then it is not a handle connection issue....................I could not make a better connection............the two parts cannot come loose as far as I can see..............but the shifter works great!!!!
Cheers!!!
Old Jan 12, 2007 | 10:28 AM
DragonPL's Avatar
DragonPL
How hard was it to install it??
