Hurst shifter?
Old Apr 19, 2007 | 02:27 PM
Green Machine 123's Avatar
Green Machine 123
Default Hurst shifter?
just woundering if there is the only one after market shifter for our cars and was it worth the money in how it feels and looks and performs???? post pics if u can thanx...
Old Apr 19, 2007 | 02:50 PM
billybix76's Avatar
billybix76
Default RE: Hurst shifter?
Actually there are 4 or 5. I put on a Saleen short shifter adapter so I could use stock 12.5mm shifter thread for my MRT shift ball. Lowest cost at 50ish bux easiest to install and works great for me. shift is must shorter and crisp. Hurst is the most popular of the full replacement kits though, but Saleen, Steeda, B&M, Ford Racing(basically a hurst), and Pro 5 all make shifters that work. Each install has its own proponents..Use the search feature on the site to look up threads on each as they have been discussed in large quantities....
Old Apr 19, 2007 | 05:08 PM
nonstopred's Avatar
nonstopred
actually...for the v6, all of those wont work...B&M and steeda and ford racing are all for the gt's. We have different trannys then the gts and therefore require slightly different shifters
Old Apr 19, 2007 | 07:12 PM
billybix76's Avatar
billybix76
Well with all due respect red, I know for a fact that Steeda, Hurst, and pro 5 will fit cause i seen em with my own eyes...on v6 T5s.... I dont know how or if they had to mod em to fit. in any case the Hurst is best if your into the look and spending 180bux, for the same action the Saleen is 50Bux...lost of custom boots, ***** and stuff for the remianing $100+..
Old Apr 19, 2007 | 08:00 PM
nonstopred's Avatar
nonstopred
....you can get the steeda which is the same as the saleen but not the tri-ax...hurst makes a separate one for the v6..that, I know. What is the pro 5 shifter...I cant find it any where?
Old Apr 20, 2007 | 02:21 PM
billybix76's Avatar
billybix76
Do a search on the forums for a "pro 5 shifter" you'll find lots of posts but a specific one for install on the T5...
carid
Jul 8, 2016 09:55 AM
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
