Heater Problem
Old Apr 23, 2007 | 12:37 AM
57Heavy's Avatar
57Heavy
Default Heater Problem
Anybody else haveing this problem? With the heat turned all the way down the vents are pouring out hot air.(Not in the recirculation mode). The outside air is only about 55 degrees so,I shouldn't have to turn the A/C on to cool off the interior. I know I could roll the windows down,but I shouldn't HAVE TO. Anybody else notice this? I have an'07 Pony package with manual trans,. Thanks.
Old Apr 23, 2007 | 12:47 AM
wolfey2k's Avatar
wolfey2k
Default RE: Heater Problem
I presume you're talking about the same level of heat as if you actually have the **** turned all the way up to maximum temp.
With the **** turned all the way cold and the mode selector **** set to OFF, you'll feel some heat flowing through the vents.
What I do is set the mode to heat, then turn the **** all the way cold and that seems to keep any residual heat from flowing out of the vents.
I know OFF should mean no flowing hot or cold air at all but I think the flapper door sets into a neutral position or something which allows some of the heat from the heater core to get through anyway.
Or if you're doing the same thing as me and are still getting a lot of heat out of your vents, then you have a problem somewhere. Might require a visit to the dealer to diagnose and repair.
I haven't looked it up yet because I don't have any problems with my 07 pony, but by the feel of the temp control ****, I'd say it's a variable resistor that controls a motorized flapper door that selects between the heater core and A/C core just like on older cars that are controlled by a cable or other mechanical linkagefrom the ****.
Another guess is there may be a fuse for that? Have you checked your owners manual?
Hope this helps. I know what a pain it can be having heat blowing when you don't need it.
Hope this helps you.
Wolfey2k
Old Apr 23, 2007 | 12:53 AM
57Heavy's Avatar
57Heavy
Thanks Wolfey, what I was trying to do was have cool outside air come through the vent by turning the position **** to vent and the temp **** all the way to cold (Fully counter-clockwise).Fan switch to 1 or 2. Guess I could have made myself clearer.
57 Heavy
Old Apr 23, 2007 | 12:57 AM
wolfey2k's Avatar
wolfey2k
No prob' 57.
So you feel a lot of heat in that mode or a little bit or what?
Should be equal to outside temp after say 10 minutes or so depending on how warm your ducting is before hand.
You should feel no artificial heat whatsoever IMO. I don't when I use the same setting.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
