NEWW 1/4 MILE TIMES!!!!
Old 05-05-2007, 01:08 AM
SilversurferV6
SilversurferV6's Avatar
Default NEWW 1/4 MILE TIMES!!!!
well i ran it my worst time was 15.8 my best is.......
r/t= .523
60= 2.382
330= 6.617
1/8= 10.042
mph= 72.25
1000= 12.954
1/4= 15.409
mph= 91.42
my mods are an aem brute force intake, pypes axleback, and no tune, automatic. think i did better than i thought i was feeling 15.8 but then it kept getting better 15.6 then 15.5 then 15.409 then i hadta go home haha, it was a bit humid out, and warm 65-70 degrees
SilversurferV6 is offline
Old 05-05-2007, 01:35 AM
28HopUp
MF Administrator
28HopUp's Avatar
Default RE: NEWW 1/4 MILE TIMES!!!!
Nice!!! So, at which track in NJ did you run it?
28HopUp is offline
Old 05-05-2007, 01:37 AM
SilversurferV6
thanks man.......Island raceway park in hacketstown
Old 05-05-2007, 04:01 AM
rmays06
rmays06's Avatar
Not bad man, Little more at the track and your times will come down. Also maybe a tune will help too!
rmays06 is offline
Old 05-05-2007, 05:54 AM
fazm
fazm's Avatar
congrats man, autos really need a tune though id bet a tune will get u into the 14s with the mods u have
fazm is offline
Old 05-05-2007, 10:33 AM
rygenstormlocke
rygenstormlocke's Avatar
Good job improving on your ET's. With a tune you can wittle it down for sure. Your 60ft could use some work, did you take out the spare tire and jack.....drop your rear tire pressure, make sure your front tires were at max pressue? Also, what RPM were you launching at.
rygenstormlocke is offline
Old 05-05-2007, 01:43 PM
SilversurferV6
i launched at about 1500 rpm, and had all tires at 35 psi, could i have done anything better?
Old 05-05-2007, 01:54 PM
rygenstormlocke
Remove your spare tire, jack and optional, lower rear seat. Also remove the carpet/wood from your trunk. Make sure your OD is off. Do a quick spin of the tires to clean them, but do not do a burn out. Set your front tires to max psi (there is usually air at the track) and set your rears to 28psi, you can dial it down to 25psi if you are need too.
Then, power brake to 1500, on the next pass, power brake to 1600, etc in increments of 100 rpm until you find the max RPM you can launch at without tire spin. Also, when staging to the tree, pump your brakes like crazy. This will get your brake pressure up and allow you to power brake the car at a higher rpm.
Good luck.
Old 05-06-2007, 07:15 PM
ricekiller06
ricekiller06's Avatar
not gonna lie you really need to work on your reactoin time. thats really bad for an automatic and even for manual though. but just saying not to be personal or anything
ricekiller06 is offline
Old 05-06-2007, 07:17 PM
fazm
fazm's Avatar
ORIGINAL: ricekiller06
doesnt effect his ET and hes not bracket racing, so it dont matter
fazm is offline
Quick Reply: NEWW 1/4 MILE TIMES!!!!
