will i be safe!!!!???!?!
Old Jun 30, 2007 | 02:14 AM
SilversurferV6's Avatar
SilversurferV6
Default will i be safe!!!!???!?!
K i dont have enough bucks for the t-lok along with my procharger to get both wheels movin however i am getting the procharger stage 2 intercooled, will my car handle alright with just one wheel spinnin, can i live with it for a few months till i have the money for the t-lok. i do have extra money for a nice set of tires in the back. with 10psi of boost and some sticky tires will i be aright for now???as long as i run low 13s ffor now i can live with myself haha any help would be much appreciated. thanks
Old Jun 30, 2007 | 05:37 AM
ricklmesa@cox.net's Avatar
ricklmesa@cox.net
Default RE: will i be safe!!!!???!?!
You don't haft to get the tlok right away. I think armycook had a procharger before any other modlol. You will want to do it in the future though for sure. It will probobly get frustrating with all that power going to one wheel lol. Consider some LCA's and a UCA too.
Old Jun 30, 2007 | 05:52 AM
Torch_Vert's Avatar
Torch_Vert
In some ways the car will "handle" better (but not faster)off the line with the stock differential.
Look at it this way:
With a limited slip, if you're spinning both tires at the line, there's nothing to prevent the rear of the car from sliding sideways (usually not a lot, but it happens).
With an open diff, if you're lighting up the right rear, the left rear tire may not be doing much to get you moving, but it is keeping the rear end planted side to side
Old Jul 1, 2007 | 02:31 AM
SilversurferV6
thanks for the infio i think im gna go witouth the t-lok for now but will i be in the low 13s with an automatic, wut if i got 3.73 gears?
Old Jul 1, 2007 | 03:29 AM
02MustangV6DD's Avatar
02MustangV6DD
Should be, If you have low miles i would install the Locker and gears before the blower, that way you dont need a full rebuild for your rear end. Also why get the tires before the locker? You will just rip the **** outta 1 tire
Old Jul 2, 2007 | 08:14 PM
SilversurferV6
but can i run 13s with a procharger at 10
psi and a pypes axleback
Old Jul 2, 2007 | 08:15 PM
SilversurferV6
i mean can i run low 13s lol
Old Jul 2, 2007 | 08:43 PM
chrisc's Avatar
chrisc
if you want to get gears in, you should just get the tlok in with them
as for low 13's...i dont think it is gunna happen with the peg leg. and if you run drag radials you will have a big possibility to break the rear end
Old Jul 3, 2007 | 01:15 AM
azstanglover's Avatar
azstanglover
Make sure you inspect the supercharger regularly for problems. There is a thread in the 4.0 drivetrain section where someone blew his engine because his supercharger was leaking oil into the engine. I'm sure you don't want something like that to happen to you. It may not happen often but it does happen
Old Jul 3, 2007 | 02:03 AM
SilversurferV6
k with that said im def gettin a t-lok but thats all for now thanks guys for your help. ill keep posted on how it goes this week with install and all and track times next week
