How do you keep the engine clean?
Old Sep 21, 2007 | 10:55 PM
Rhino77's Avatar
Rhino77
Default How do you keep the engine clean?
Hi fellas, I really want to keep my engine clean, both inside and out.
I plan on Seafoaming at about 20K, however I'm curious as to how to keep the outside/aesthetics of the engine pristine every 10,000 miles or so.
I've never kept the outside of the engine clean in any of my cars, 'cause frankly, I don't know how.There is pleny of electronics and mechanics going on in there, and I don't want to screw up any of the intakes/electronics/plugs etc, inside of the engine.
Is it safe to shoot the engine with high powered steam spray, or better to spend the money and have it professionally steam cleaned?Cost for pro steam cleaning? Any information on this subject would be greatly appreciated.
Old Sep 22, 2007 | 12:33 AM
Nsomnia's Avatar
Nsomnia
Default RE: How do you keep the engine clean?
I spray it with highpressure hose (from a safe distance obviously, dont wanna rip up any wires) then clean it with a rag and water by hand.
Im intrested too in seafoaming soon, any tips from fellow mustang owners?
Old Sep 22, 2007 | 06:00 AM
06musgt's Avatar
06musgt
every 6 months or so,i clean mine.i cover the battery and distributer with walmart plastic bags then prewet it with a garden hose,soak it with a cleaner(simple green from the auto store works good)then after a min or so,hose it down.i dry what i can,then i use 2001(like armorall)and shine everything i see thats plastic.
Old Sep 22, 2007 | 08:40 AM
red07Pony's Avatar
red07Pony
On the SPEED channel there is a show that's been around forever called MotorWeek. On that show there is a segment called Goss' Garage. Pat Goss is the host and he did an episode on exactly this topic. Pulling from memory he did just what 06musgt said which is using plastic grocery bags to cover the fuse box, battery, distributor and...(I'm not sure what else if anything else because again this is from memory) but then sprayed on an engine degreaser/cleaner and rinsed it off. The point I took away from that show was that you have to be very careful not to get water in any of the electrical components otherwise you can screw up the sensors and you'll have all kinds of problems. So just double bag those areas and have at it and you should be fine.
If they play reruns you may want to try and catch it, set your DVR to record the show and maybe you'll get lucky. The episode I saw was only about a month or two ago.
Old Sep 22, 2007 | 08:58 AM
68XR7's Avatar
68XR7
I've always felt that to keep the engine clean was easier than trying to get the engine clean. I clean mine quite often. I use a power washer with soap first then the rinse. I've never had a problem of any kind.
Old Sep 22, 2007 | 08:45 PM
basketballord's Avatar
basketballord
They also recommend to cover up the factory airbox
Old Sep 23, 2007 | 01:41 AM
VictoriaRR's Avatar
VictoriaRR
ORIGINAL: basketballord
Yea, you don't want water shooting into your engine!
Old Sep 23, 2007 | 12:57 PM
157dB's Avatar
157dB
Cut & Paste Expert
Read the owners manual. Its spelled out in there.
Old Sep 23, 2007 | 01:28 PM
Dwisforme05's Avatar
Dwisforme05
i use black magic engine cleaner. the stuff works great! i spray it on and rise off with a power washer. not on full blast tho!
Old Sep 24, 2007 | 07:23 AM
banka87's Avatar
banka87
wtf is seafoaming?
