Performance Mod
Old Oct 18, 2007 | 07:44 AM
gln3's Avatar
gln3
Default Performance Mod
Looking for performance modifications for V6 Convertible that are reasonable affordable and can be done by novice. Car is still under manufactures warranty and is a casual driver (weekends), not looking for drag strip performance but good road performance on scenic 2 lane road cruises and on country roads and mountain terrain. Just a little something extra to make a weekend run a little more exciting.
Old Oct 18, 2007 | 08:12 AM
Wickerbill's Avatar
Wickerbill
Default RE: Performance Mod
Kinda contradicting there. You want a lil more performance but you also want to retain your warranty and not spend alot of money...haha j/k
Most of your responses will probably say CAI/Tuner. This will add performance and can pretty much be completed by a novice withlittle experience, as long as you can follow step by step directions. Though I dont know if the $500 is in your budget.
Gearsand Traction Lock is another option that doesnt take a whole lot of funds, butcannot be installed in the driveway by a novice.It doesnt add any power but moves the power down to a more useful RPM range to make drivingmore enjoyable. But you add in the cost of installation and your talking more money than the Intake/Tunercombo.
There are otherperformance mods you could go with but these are the most popular two with the most noticeable gains on a lower budget. You could also go dual exhaust but without any other mods this wont give you much noticeable gain in power but rather the sound. As for warrantyit doesnt matter what partsyou install or get installed as these parts WILL NOT be covered underfactory warranty. In most cases though modding your car wont void your whole warranty, unless the dealer can prove that your breakdown is caused by the aftermarket part/s.
Old Oct 18, 2007 | 09:02 AM
28HopUp's Avatar
28HopUp
MF Administrator
ORIGINAL: gln3
I would suggest getting a single GT take-off muffler. We have one on our S197 vert, and it sounds great without being too loud - top up or down. You may have to buy both sides, but they are so cheap it's still a bargain if you only use the passenger side.
If you have the 16" wheels, I would recommend upgrading the tires. There are very good tires available for the 16" rims, or you could get a set of 17" GT take-off rims/tires, and use your 16" rims for snow tires if that applies (or sell the 16's to offset the cost of the 17's). The 17" Pirellis or 18" BFG's are a big improvement over the 16" BFG's.
If you don't have the Pony Package, you can get some GT take-off sway bars. You can also upgrade your front rotors and calipers with GT take-off units (available from Saleen), which will improve your braking power.
Old Oct 18, 2007 | 09:43 AM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Just out of curiosity, how much work is it to change out the rear rotors to GT take-off's?
Old Oct 18, 2007 | 11:10 AM
chrisc's Avatar
chrisc
ORIGINAL: ODDYSEY
not very much, because they are exactly the same as the V6 rotors lol
Old Oct 18, 2007 | 11:19 AM
Wickerbill's Avatar
Wickerbill
yep I think they are the same, GT500 are bigger but they also run a 18" wheel with a different backspacing to accomodate.
firecoyote
Sep 27, 2015 02:37 PM
warwickbass
Sep 20, 2015 04:51 PM
Roush05
Sep 10, 2015 12:23 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 11:50 AM
