Caster Camber Plates?
Old Oct 25, 2007 | 07:16 AM
LesteR723's Avatar
LesteR723
Default Caster Camber Plates?
are they nessicary for a dropped car if it got aligned?
Old Oct 25, 2007 | 08:30 AM
Wickerbill's Avatar
Wickerbill
Default RE: Caster Camber Plates?
They may or may not be needed. It all depends on if the drop makes the alignment go beyond the adjustments you can achieve with the factory setup. I dont know how much they run or what a good price on them would be, but it is a mechanics dream to get a alignment job and see there is caster/camber plates installed.
Old Oct 25, 2007 | 08:43 AM
boss 244's Avatar
boss 244
You can get exellent ones from hotpart.com. I have them and they were necessary with a 1 1/4" drop. Makes the car handle soooo much better than without them.
Old Oct 27, 2007 | 11:47 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: LesteR723
Is this a trick question?
If it was aligned properly, then no they are not required.
baddog671
Jul 26, 2016 01:20 PM
Explosive
Oct 2, 2015 07:45 AM
mdg
Oct 1, 2015 07:04 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
