Question About Y-Pipe
Old Nov 7, 2007 | 11:48 AM
proper's Avatar
proper
Default Question About Y-Pipe
I was talking to my cousin the other day and hes the one I go to for hook ups for my mustang since he use to have a sn95 before. My question is was when I was talking to him I told him I wanted to go dual exhaust and which pipe should i do X or H. He was telling me theres no point into doing an X or an H cuz im only pushing a v6... He told me to just get another flowmaster 40 and buy some pipping that would split my pipe from the catyltic converter to add another exhaust.
Old Nov 7, 2007 | 12:15 PM
Sancho805's Avatar
Sancho805
Default RE: Question About Y-Pipe
he's right as long as you stay N/A. i like the fact that i have true duals and in contrary to what others have said about true duals losing in the low end, i haven't noticed a thing. if anything, i feel a bit more pull in the high end. but if you stay N/A or have no urge for true dual, y-pipe should do just fine.
Old Nov 7, 2007 | 03:32 PM
nonstopred's Avatar
nonstopred
yeh just doing a reverse y will be fine. I havent noticed a negative to mine, but the performance out of the ys are good enough
Old Nov 7, 2007 | 03:52 PM
Sancho805's Avatar
Sancho805
one more thing: h-pipe setup is known for having the best sound (beefier tone) of the three. not a BIG difference but enough to notice. if you are picky with the sound, then you may want to do some more research of each setup so that you get exactly what you want the first time.
Old Nov 7, 2007 | 04:04 PM
28HopUp's Avatar
28HopUp
MF Administrator
ORIGINAL: proper
The factory y-pipe has a catalytic converter on each side of the motor coming off each exhaust manifold. You can cut the y-pipe after the cats to set up your duals. MyGT x-pipe is mounted to the cut-off factory y-pipe.
Old Nov 7, 2007 | 04:49 PM
proper's Avatar
proper
o ok cool thanks for the info guys! i'll stick to the reverse Y since I'm not going the route of FI I'm just trying to get sound and performance through the NA route. hey nonstopred do u have any sound clips of your reverse y pipe.
Old Nov 7, 2007 | 05:39 PM
davesyo's Avatar
davesyo
I have the Y set from ninosport on my car with dual gt's and am more than happy with it.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
