Please help
Old Nov 29, 2007 | 07:51 PM
GNARLY PONY's Avatar
GNARLY PONY
Default Please help
Hi all,
I was hoping that someone can tell me how to remove my front grill.
05vert
Old Nov 30, 2007 | 08:42 AM
28HopUp's Avatar
28HopUp
MF Administrator
Default RE: Please help
I have removed the entire front bumper and grill from my car, but I did it as one section together. One bit of advice I can give you: Ford uses 2-piece press-in plastic fasteners for things like the radiator cover. To remove them, you first need to pry up the round center section of the fastener before pulling out the entire thing. If you try to pull it out as one piece from the outside edge without pulling up the center part, it'll break.
Old Nov 30, 2007 | 09:43 AM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
This thread may help you.
https://mustangforums.com/m_1121391/tm.htm
Old Nov 30, 2007 | 08:24 PM
GNARLY PONY
Thanks!
Old Nov 30, 2007 | 08:35 PM
05nightrider's Avatar
05nightrider
i found the easiest way was to use a screwdriver to pry the back of the plastic tongue and then slide the other side out
Old Nov 30, 2007 | 08:37 PM
GNARLY PONY
ORIGINAL: 05nightrider
Won't they break?
Old Nov 30, 2007 | 08:40 PM
Fallout's Avatar
Fallout
dude i spent some time yesterday trying to remove the factory grill, it pissed me off to no end and i eventually gave up(may try again tomorrow)once you take the black cover off, take the two small silver bolts out thatare between the grill and the headlights, it will allow more flex..the 2 tabs on each side are easy to get out, the 5 across the bottom will be a bitch, what makes it worse is if you have fogs, because they are directly over the tabs on each end, making them almost impossible to get to.
i assume you want to remove it because you bought a new one, i'll probably say screw it, and break the stock tabs so i can get it out easier...
Old Nov 30, 2007 | 08:47 PM
GNARLY PONY
ORIGINAL: Fallout
I know what you mean, they did not make it easy.
Old Nov 30, 2007 | 09:42 PM
afixer's Avatar
afixer
here is an artical they did on the SS grill install with my car back when she was jus a yearling!
http://www.thechromepony.com/Mods1-05.html
i can take my grill off and on in less than 20 min!
Old Dec 1, 2007 | 09:06 AM
157dB's Avatar
157dB
Cut & Paste Expert
My stock grill came off real easy as none of the bottom tabs were properly engaged
from the factory. The only tabs holding my stock grill on were the ones on the sides.
Took about 5 mins and it was off.
