Ebay Headers installed
Old Dec 10, 2007 | 11:16 AM
MN Moose's Avatar
MN Moose
Default Ebay Headers installed
I posted this over at the stang c.o.l.l.e.c.t.i.v.e. so some of might have already seen it.
The Headers
I started seeing a bunch of cheap "chinese" headers on ebay for the 4.0 about a month ago for fairly cheap. I started looking around for some and found out that ACRBILL was selling his on the collective. I got them for the cheap price of $115 shipped. Thanks Bill! The Headers are very light compared to the stock manifolds that i yanked off. The welds are really good around the flanges and the interior welds to keep the 3 individual pipes together seemed pretty good but not great. I was kind of concerned that i would get a leak or two and this kind of scared me... I opted not to get them ceramic coated because i don't have the funds for it and i have heat extractors on my hood. Ceramic coating would probably be a good idea for anyone who has the money though.
The Install. . .
-The install took A LOT longer than predicted. Total time invested was around 10 hours in this, mainly because i was being careful with everything. I only had one bolt give me a hard time and that was the 15mm bolt that holds the coil pack mount to the engine block. I used my friend's Engine dolly arm and slid it over the end of the socket wrench and gave it hell. The header flanges themselves weren't really cut perfect... Basically what i mean is the holes that are predrilled in the flanges don't line up perfect with the head studs on the block. I just used a hammer and pounded the flanges until they slid onto the studs right, this made for the headers being nice and snug against the block. Hammering them in cold weather probably wasn't the best idea because the welds might break but it all worked out fine in the end.
One side note is to get under the car and unbolt your crossover pipe from the cats so you can line the cats up right with the headers so there isn't any leaks. The xpipe was sealed to the cats pretty well but thats where the BFH (as mrjimmy would call it) came out. I just hit the edges a few times and it loosened up the rust and what not for the cats to slide around just enough to line them up with the headers right.
Post Install
I surprisingly didn't have any leaks at all after installing! i was pretty relieved. The Stainless Steel has started changing colors already, first a goldish color now its turning blue but it really doesn't bother me, anything looks better than those rusty and hefty stock manifolds.
The Difference
Sound
The car definitely has a different tone when it idles. I didn't really notice at first but after a few days i started to hear the difference. The idle is a little bit deeper and just seems like the car has a tad bit bigger *****. Now don't get me wrong here, the change isn't big at all. I was hoping that the tone would change drastically but that isn't what happened. Unless you're obsessed with your car, like i am, you shouldn't notice a big or even mild difference. It just gives the exhaust that little extra. It doesn't change much during revs either. Its does make it a bit more raspier according to MY ears though.
Drive
The first little spin i took through town didn't really show me anything. After driving it for a couple weeks or so i definitely do notice a difference now. Again, its not a big change or even mild. It just seems to add a little more GO to the car. The change is biggest at WOT obviously, the engine seems like it wants more now.
Overall
I am VERY happy with these headers, for $115 shipped it was a phenomenal deal! (thanks again bill). I had 0 leaks and very little trouble with these, i even used the supplied gaskets with them. JUST DONT USE THE CHEAP A$$ CHINESE BOLTS, i twisted off the heads on 2 bolts, one of which is STILL in my engine block. I'll get it out eventually... You can find these headers on ebay or http://www.ssautochrome.com
Pics are of headers out of the box, drivers side installed, passenger side installed, and the makeshift workspace.
Old Dec 10, 2007 | 04:55 PM
Kevjud's Avatar
Kevjud
Default RE: Ebay Headers installed
Nice write up. By the way, I like your work light!
Old Dec 10, 2007 | 04:59 PM
samv1368's Avatar
samv1368
nice write up!
Old Dec 10, 2007 | 05:06 PM
Sancho805's Avatar
Sancho805
+1 on the write up.......NOW, about the quality....are you worried at all with these chinese headers in the long run? there has got to be a catch[>:].
Old Dec 14, 2007 | 01:15 AM
JudgeThis's Avatar
JudgeThis
They look really small for some reason? I've been wanting to do headers and full exhaust on the mustang for some reason, but i'm still weary.
Old Dec 14, 2007 | 07:57 PM
MN Moose's Avatar
MN Moose
ORIGINAL: JudgeThis
yeah. they're short tube headers. emphasis on short tube. They're the exact same thing as the JBA shorty headers. except an 8 year old chinese girl made them instead of a machine.
Old Dec 14, 2007 | 09:05 PM
JudgeThis's Avatar
JudgeThis
ORIGINAL: MN Moose
ORIGINAL: JudgeThis
NO kidding. The pic for some reason makes the primaries took tiny.... I've had cars with headers before... [8D]
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
TimeLord101
Sep 4, 2015 09:27 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
