Are these numbers right?
Old Jan 28, 2008 | 09:04 PM
The Potato's Avatar
The Potato
Default Are these numbers right?
I've been looking at what gains I can get with some bolt ons, here's what I'm getting. Do these sound right?
- C&L CAI w/ SCT X-CAL 2 tuned by Brenspeed - ~20hp / ?? ft. lb. torque
- MRT Aero Turbine Axle-back exhaust - ~10hp / ?? torque (anyone have a number?)
- Screamin' Deamon Coil + Livewires - 14.3hp / 12.2 ft.lb. torque (claims MM&FF)
the numbers I'm coming up with is ~244hp and ~272 ft. lb. torque (if the hp and torque gains are the same)
Is there anything else that I can do that can give me more torque besides f/i?
Old Jan 28, 2008 | 09:14 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: Are these numbers right?
you are starting at around 170 stock so with those mods 205-215 is a better guess...mods dont necessarily add on top like that either....so results may vary
Old Jan 28, 2008 | 09:22 PM
The Potato's Avatar
The Potato
Ah, I see. I started with 180 hp and 210 torque stock also.
Old Jan 28, 2008 | 10:41 PM
MrSandman's Avatar
MrSandman
i've seen stock 4.0s dyno at 180..so who knows.
Old Jan 28, 2008 | 10:47 PM
Jsierzega's Avatar
Jsierzega
14.3 hp from ignition cables!? some one has been having a little too much happy smoke
Old Jan 29, 2008 | 01:21 AM
my first mustang's Avatar
my first mustang
Never believe advertising claims! especially coil and spark plug wires.
Old Jan 29, 2008 | 01:31 AM
chrisc's Avatar
chrisc
Sounds about right, except the coil pack and wires, probably more like 5hp to the crank. If you are talking crank numbers, then yeah, 260hp is reasonable. Which issue did you see the Screamin Demon coil pack tested? If you saw the packs for the GT, you are off a lot, the GTs get a lot of power from the packs.
Old Jan 29, 2008 | 11:30 AM
The Potato's Avatar
The Potato
V6 Spark plugs + Screamin' Deamon for 3.8 and 4.0 Mustangs, found in the March issue of MM&FF
Old Jan 30, 2008 | 01:40 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
I still think those numbers are a little high but the gains are possible. The only way to know that is to get it dyno'ed to see what your numbers are before and after the modifications. JMO J
Old Jan 30, 2008 | 07:34 PM
The Potato's Avatar
The Potato
any other mods that I should do for power besides f/i?
